[QGIS-Developer] Permission Issues during Flatpak Install on NIS clients
Richard Duivenvoorde
rdmailings at duif.net
Tue Apr 26 23:15:52 PDT 2022
Hi Quentin,
I think it is better to ask this in the issue tracker of the github packager:
https://github.com/flathub/org.qgis.qgis/issues
There they are probably more aware of such details.
Regards,
On 4/26/22 23:36, Coles, Quentin (GSFC-423.0)[RAYTHEON COMPANY] via QGIS-Developer wrote:
> Hello All,
> Has anyone had an issue installing Flatpak QGIS on Rhel 8 where the permissions on many directories show up with question marks in the permissions like the following:
> # cd /view/NightlyBuild_linux/var/lib/flatpak/runtime/org.kde.Sdk/x86_64/5.15-21.08/61a7c1ac873ecbfbdae4442a28da9d1356d105c2d6f8c9c9a719012cab99fe32/files/lib
> [root at i8oml01v lib]# ls -al
> ls: cannot access 'os-release': Permission denied
> total 136
> drwxr-xr-x 20 root root4096 Dec 311969 .
> drwxr-xr-x 14 root root 263 Apr 25 14:56 ..
> drwxr-xr-x2 root root 6 Dec 311969 aarch64-linux-gnu
> drwxr-xr-x2 root root 6 Dec 311969 arm-linux-gnueabihf
> drwxr-xr-x2 root root17 Dec 311969 debug
> drwxr-xr-x4 root root41 Dec 311969 extensions
> drwxr-xr-x3 root root38 Dec 311969 gcc
> drwxr-xr-x2 root root 6 Dec 311969 i386-linux-gnu
> lrwxrwxrwx1 root root39 Apr 25 14:56 ld-linux-aarch64.so.1-> *aarch64-linux-gnu/ld-linux-aarch64.so.1*
> lrwxrwxrwx1 root root39 Apr 25 14:56 ld-linux-armhf.so.3-> *arm-linux-gnueabihf/ld-linux-armhf.so.3*
> lrwxrwxrwx1 root root28 Apr 25 14:56 ld-linux.so.2-> *i386-linux-gnu/ld-linux.so.2*
> drwxr-xr-x 36 root root 12288 Dec 311969 locale
> drwxr-xr-x 76 root root4096 Dec 311969 mkspecs
> -?????????? ???? os-release
> drwxr-xr-x4 root root37 Dec 311969 perf
> drwxr-xr-x5 root root56 Dec 311969 perl5
> drwxr-xr-x 40 root root4096 Dec 311969 plugins
> drwxr-xr-x 32 root root8192 Dec 311969 python3.9
> drwxr-xr-x 23 root root4096 Dec 311969 qml
> drwxr-xr-x2 root root 6 Dec 311969 sdk
> drwxr-xr-x3 root root20 Dec 311969 systemd
> drwxr-xr-x3 root root21 Dec 311969 tcl8.6
> lrwxrwxrwx1 root root17 Apr 25 14:56 terminfo-> ../share/terminfo
> drwxr-xr-x4 root root39 Dec 311969 udev
> drwxr-xr-x 55 root root 69632 Dec 311969 x86_64-linux-gnu
> These type files are littered throughout the directory structure above. I think the issue is because of the NIS system where those users don’t exist locally on the server. Does anyone know what the username should be or any other workaround for this type of problem?
> Thanks in advance
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
