[QGIS-Developer] setDataSourceUri() not working
Raymond Nijssen
r.nijssen at terglobo.nl
Wed Dec 7 07:39:50 PST 2022
Hi Devs,
I'm trying to change the dataSourceUri of an existing layer, but can't
get it working. The reason is that my layer should be connected to
another view in the same database, because the db should do some
calculations for my plugin.
I created a test script for a simple polygon layer in a gpkg, which I
attached to this email. The layer "polygons" and both views are all
working correctly if you just drag and drop the gpkg in QGIS.
Open the polygons layer and select it. Then run:
layer = iface.activeLayer()
provider = layer.dataProvider()
ds = provider.dataSourceUri()
print(ds)
fn = ds.split('|layername=')[0]
new_ds = fn + '|layername=highest_3_view'
print(new_ds)
provider.setDataSourceUri(new_ds)
The first run displays 2 different dataSourceUris:
path/to/test_views.gpkg|layername=polygons
path/to/test_views.gpkg|layername=highest_3_view
The second run displays 2x the same dataSourceUris:
So the string has been changed. But my layer properties still point to
and the features displayed are all 5 from the polygons layer. (The views
have only 3 features)
Should i do something after setting the new provider? I've been trying
many things, including:
* provider.reloadData()
* layer.setDataProvider(dataprovider)
* refreshing/redrawing the layer
Hope anyone can help!
Raymond
Type: application/geopackage+sqlite3
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20221207/9281402b/attachment-0001.bin>
