[QGIS-Developer] setDataSourceUri() not working
Julien Cabieces julien.cabieces at oslandia.com
Thu Dec 8 10:12:24 PST 2022
dataSourceUri is used when creating the dataProvider/vectorlayer and
there is no way to refresh the provider according to a new uri.
I don't see any other way than recreate a new QgsVectorLayer with the
new dataSource uri, add it to your project instance with addMapLayer and
remove the old one.
Maybe there is a trick to simplify things but I fail to see how.
Regards,
Julien
> Hi Devs,
> I'm trying to change the dataSourceUri of an existing layer, but can't
> get it working. The reason is that my layer should be connected to
> another view in the same database, because the db should do some
> calculations for my plugin.
> I created a test script for a simple polygon layer in a gpkg, which I
> attached to this email. The layer "polygons" and both views are all
> working correctly if you just drag and drop the gpkg in QGIS.
> Open the polygons layer and select it. Then run:
> layer = iface.activeLayer()
> provider = layer.dataProvider()
> ds = provider.dataSourceUri()
> print(ds)
> fn = ds.split('|layername=')[0]
> new_ds = fn + '|layername=highest_3_view'
> print(new_ds)
> provider.setDataSourceUri(new_ds)
> The first run displays 2 different dataSourceUris:
> path/to/test_views.gpkg|layername=polygons
> path/to/test_views.gpkg|layername=highest_3_view
> The second run displays 2x the same dataSourceUris:
> So the string has been changed. But my layer properties still point to
> and the features displayed are all 5 from the polygons layer. (The views
> have only 3 features)
> Should i do something after setting the new provider? I've been trying
> many things, including:
> * provider.reloadData()
> * layer.setDataProvider(dataprovider)
> * refreshing/redrawing the layer
> Hope anyone can help!
> Raymond_______________________________________________
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
More information about the QGIS-Developer mailing list
