[QGIS-Developer] OpenID Connect authentication
    Paul Wittle
    paul.wittle at dorsetcouncil.gov.uk
    Fri Dec  9 08:04:36 PST 2022
I have a web service that I've configured to use OpenID Connect for authentication. I'm aware that QGIS supports Oauth2 authentication and I believe that could work for the authentication but can you confirm whether it is possible to overwrite the redirect URL?
The reason I ask is that the provider I'm using only permits redirect URLs starting with https or http://localhost. Unfortunately QGIS is forcing me to start it with http://127.0.0.1 but I need to configure it to be localhost or the request is rejected.
Thanks,
Paul
This e-mail and any files transmitted with it are intended solely for the use of the individual or entity to whom they are addressed. It may contain unclassified but sensitive or protectively marked material and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All traffic may be subject to recording and/or monitoring in accordance with relevant legislation. Any views expressed in this message are those of the individual sender, except where the sender specifies and with authority, states them to be the views of Dorset Council. Dorset Council does not accept service of documents by fax or other electronic means. Virus checking: Whilst all reasonable steps have been taken to ensure that this electronic communication and its attachments whether encoded, encrypted or otherwise supplied are free from computer viruses, Dorset Council accepts no liability in respect of any loss, cost, damage or expense suffered as a result of accessing this message or any of its attachments. For information on how Dorset Council processes your information, please see www.dorsetcouncil.gov.uk/data-protection
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20221209/715acc09/attachment-0001.htm>
