[QGIS-Developer] QgsSettings
Alessandro Pasotti
apasotti at gmail.com
Fri Dec 9 22:06:06 PST 2022
Hi Denis,
it's been a while but IIRC the goal was to have a drop-in replacement
of QSettings, that's probably why I recreated the same ctors.
On Fri, Dec 9, 2022 at 2:48 PM Denis Rouzaud <denis.rouzaud at gmail.com> wrote:
> Hi all,
> While working on the refactoring of settings (see https://github.com/qgis/QGIS-Enhancement-Proposals/issues/245), I am thinking about deprecating the QgsSettings class and directly integrate its functionality within QgsSettingsRegistry.
> I would need a bit of help to understand the rationale behind QgsSettings.
> The use of global settings is pretty clear to me and migrating this is ok.
> I am wondering about the different constructors (https://api.qgis.org/api/3.28/classQgsSettings.html) which correspond to the different constructors of QSettings.
> While it makes sense to have these constructors, I don't see them used anywhere in the code. So, it means that they are never used within QGIS application.
> I am wondering why QgsSettings isn't used with a static instance.
> So, are these constructors really used and meaningful?
> Would it make sense to have 2 static instances of QSettings (1 user, 1 global)?
> Many thanks for any input.
> Best wishes,
> Denis
Alessandro Pasotti
QCooperative: www.qcooperative.net
ItOpen: www.itopen.it
