[QGIS-Developer] Building pyqgis doc locally
matteo matteo.ghetta at gmail.com
Mon Dec 12 23:35:23 PST 2022
Hi Denis,
> The main issue is that the website is added to a branch (gh-pages) and
> is versioned.
>  From time to time, I squash the commits and force push to avoid such a
> large size (obviously, it's been a while since I didn't do it).
> I am a bit reluctant at squashing / force pushing directly from the
> workflow as any error would mean losing the pages (potentially losing
> the older versions).
> By fetching only the master branch you should be better.
got it, thanks
> Then, building docs shouldn't take too long. What duration are you
> experiencing?
just reading sources it's more than 10 minutes while building the
documentation is still running (so more or less 30 minutes). I don't
understand if/where I can skip sources and compile just a small small
part of the documentation since what I want to to is only theme related.
> Another approach is to do a PR on the repo, you will have a built
> example at https://qgis.org/pyqgis/master_PRXX
> <https://qgis.org/pyqgis/master_PRXX> (replace XX) when it's finished.
and this can be done also to the forked repository right?
> I believe it would require a bit of love to improve this workflow and
> drop the gh-pages branch.
> I hope this helps a bit.
Thanks Denis
Matteo
> Cheers,
> Denis
> Le mar. 13 déc. 2022 à 08:14, matteo via QGIS-Developer
> <qgis-developer at lists.osgeo.org <mailto:qgis-developer at lists.osgeo.org>>
> a écrit :
>     Hi devs,
>     I've some small ideas to enhance the readthedocs theme of the pyqgis
>     documentation and I want make some local test before making a pull
>     request.
>     I've cloned this repository (around 7GB?!):
>     https://github.com/qgis/pyqgis <https://github.com/qgis/pyqgis>
>     and then I followed the instruction of the Readme file. It seems
>     building but it is literally taking ages (./build-docs.sh
>     -qgis-build-dir /home/matteo/dev/qgis-master/).
>     Am I doing something wrong or can I use some shortcut to build it? I'm
>     just playing with some css and eventually the config.py.in
>     <http://config.py.in> file.
>     Cheers and thanks for any advice
>     Matteo
>     _______________________________________________
>     QGIS-Developer mailing list
>     QGIS-Developer at lists.osgeo.org <mailto:QGIS-Developer at lists.osgeo.org>
>     List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>     <https://lists.osgeo.org/mailman/listinfo/qgis-developer>
>     Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
More information about the QGIS-Developer mailing list
