[QGIS-Developer] Skip loading plugin if errors
Germán Carrillo carrillo.german at gmail.com
Wed Dec 28 01:40:12 PST 2022
Hi Matteo,
I've added a few validations for this plugin to gently inform users of
missing dependencies:
https://github.com/SwissTierrasColombia/Asistente-LADM-COL/blob/master/asistente_ladm_col/__init__.py
Hope that helps.
Regards,
Germán
El mié, 28 dic 2022 a las 9:58, matteo via QGIS-Developer (<
qgis-developer at lists.osgeo.org>) escribió:
> Hi devs,
> I'm developing a Processing provider plugin that needs some external
> python packages. If these are not installed on the system, when starting
> QGIS and loading the plugin the error message pops up (of course).
> Is there a way to have a "more friendly" message without opening the
> Stacktrace? For example creating a messagebox/bar with the message
> "Install the package...... else you cannot use the plugin"
> I've added a simple try/except in the plugin classFactory method but I'm
> still stuck in the loop somewhere.
> Thanks for any suggestion
> Cheers
> Matteo
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
   |\__
(:>__)(
Soluciones Geoinformáticas Libres
http://geotux.tuxfamily.org/
https://twitter.com/GeoTux2 <http://twitter.com/GeoTux2>
<http://gis.stackexchange.com/users/4972/germ%c3%a1n-carrillo>
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20221228/ea9dda89/attachment.htm>
More information about the QGIS-Developer mailing list
