[QGIS-Developer] Skip loading plugin if errors
matteo
matteo.ghetta at gmail.com
Thu Dec 29 00:26:27 PST 2022
Hi Germàn,
I successfully used also your code and it really works perfectly.
Thanks for sharing it!
Cheers
Matteo
On 12/28/22 10:40, Germán Carrillo wrote:
> Hi Matteo,
> I've added a few validations for this plugin to gently inform users of
> missing dependencies:
> https://github.com/SwissTierrasColombia/Asistente-LADM-COL/blob/master/asistente_ladm_col/__init__.py <https://github.com/SwissTierrasColombia/Asistente-LADM-COL/blob/master/asistente_ladm_col/__init__.py>
> Hope that helps.
> Regards,
> Germán
> El mié, 28 dic 2022 a las 9:58, matteo via QGIS-Developer
> (<qgis-developer at lists.osgeo.org
> <mailto:qgis-developer at lists.osgeo.org>>) escribió:
> Hi devs,
> I'm developing a Processing provider plugin that needs some external
> python packages. If these are not installed on the system, when
> starting
> QGIS and loading the plugin the error message pops up (of course).
> Is there a way to have a "more friendly" message without opening the
> Stacktrace? For example creating a messagebox/bar with the message
> "Install the package...... else you cannot use the plugin"
> I've added a simple try/except in the plugin classFactory method but
> I'm
> still stuck in the loop somewhere.
> Thanks for any suggestion
> Cheers
> Matteo
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org <mailto:QGIS-Developer at lists.osgeo.org>
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> <https://lists.osgeo.org/mailman/listinfo/qgis-developer>
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> |\__
> (:>__)(
> Soluciones Geoinformáticas Libres
> http://geotux.tuxfamily.org/ <http://geotux.tuxfamily.org/>
> https://twitter.com/GeoTux2 <http://twitter.com/GeoTux2>
> <http://gis.stackexchange.com/users/4972/germ%c3%a1n-carrillo>
