[QGIS-Developer] QgsBlockingNetworkRequest and PATCH method (Python)
Johannes Kröger (WhereGroup) johannes.kroeger at wheregroup.com
Mon Feb 7 00:53:18 PST 2022
Plus:
- The requests package might not be installed in UserX's system and thus
your plugin might just not work unless the user knows how to install
Python packages manually. urllib would always be available (though it
does not do PATCH without some tiny monkey patching:
https://stackoverflow.com/a/9023005/4828720) so use that if you really
can't use the builtin PyQGIS API.
Cheers, Hannes
Am 06.02.22 um 23:22 schrieb Nyall Dawson:
> On Tue, 1 Feb 2022 at 18:10, Julien Cabieces
> <julien.cabieces at oslandia.com> wrote:
>> I think one good solution is to use the request python framework (https://3.python-requests.org/)
> (for wider reference in case anyone comes across this thread in search
> results:)
> In general, it's better NOT to use requests and stick with the native
> PyQGIS network API instead. There's a number of reasons why using
> requests for QGIS plugin is discouraged:
> - It doesn't respect QGIS network settings, like the proxy settings
> - It doesn't use the standard QGIS handling of authentication and
> dealing with things like SSL errors
> - Requests aren't logged via the Network Logger panel
> Nyall
>> Regards,
>> Julien
Type: application/pgp-keys
Desc: OpenPGP public key
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20220207/942516ab/attachment.key>
Desc: OpenPGP digital signature
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20220207/942516ab/attachment.sig>
More information about the QGIS-Developer mailing list
