[QGIS-Developer] qgis 3.22.3 fails to compile against sip 6.5.1
Saulteau Don
sault.don at gmail.com
Fri Feb 11 15:54:19 PST 2022
I'm trying to compile QGIS 3.22.3 against SIP 6.5.1 on Arch Linux via cmake
and it fails with the following:
[ 77%] Generating core/build/_core/sip_corepart0.cpp,
core/build/_core/sip_corepart1.cpp, core/build/_core/sip_corepart2.cpp,
core/build/_core/sip_corepart3.cpp, core/build/_core/sip_corepart4.cpp,
core/build/_core/sip_corepart5.cpp, core/build/_core/sip_corepart6.cpp,
core/build/_core/sip_corepart7.cpp, core/build/_core/sip_corepart8.cpp,
core/build/_core/sip_corepart9.cpp, core/build/_core/sip_corepart10.cpp,
core/build/_core/sip_corepart11.cpp, core/build/_core/sip_corepart12.cpp,
core/build/_core/sip_corepart13.cpp, core/build/_core/sip_corepart14.cpp,
core/build/_core/sip_corepart15.cpp
File "/usr/bin/sip-build", line 33, in <module>
sys.exit(load_entry_point('sip==6.5.1', 'console_scripts',
'sip-build')())
File "/usr/bin/sip-build", line 25, in importlib_load_entry_point
return next(matches).load()
StopIteration
make[2]: ***
[python/CMakeFiles/python_module_qgis__core.dir/build.make:765:
python/core/build/_core/sip_corepart0.cpp] Error 1
make[1]: *** [CMakeFiles/Makefile2:9159:
python/CMakeFiles/python_module_qgis__core.dir/all] Error 2
make: *** [Makefile:166: all] Error 2
Donovan
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20220211/9a61274e/attachment.html>
