[QGIS-Developer] qgis 3.22.3 fails to compile against sip 6.5.1
Donovan Cameron
sault.don at gmail.com
Thu Feb 17 23:31:44 PST 2022
Appeared to be a system error, removing an old python-sip4 package fixed
the problem =)
On 2022-02-11 16:54, Saulteau Don wrote:
> I'm trying to compile QGIS 3.22.3 against SIP 6.5.1 on Arch Linux via
> cmake and it fails with the following:
> [ 77%] Generating core/build/_core/sip_corepart0.cpp,
> core/build/_core/sip_corepart1.cpp,
> core/build/_core/sip_corepart2.cpp,
> core/build/_core/sip_corepart3.cpp,
> core/build/_core/sip_corepart4.cpp,
> core/build/_core/sip_corepart5.cpp,
> core/build/_core/sip_corepart6.cpp,
> core/build/_core/sip_corepart7.cpp,
> core/build/_core/sip_corepart8.cpp,
> core/build/_core/sip_corepart9.cpp,
> core/build/_core/sip_corepart10.cpp,
> core/build/_core/sip_corepart11.cpp,
> core/build/_core/sip_corepart12.cpp,
> core/build/_core/sip_corepart13.cpp,
> core/build/_core/sip_corepart14.cpp, core/build/_core/sip_corepart15.cpp
> Traceback (most recent call last):
> File "/usr/bin/sip-build", line 33, in <module>
> sys.exit(load_entry_point('sip==6.5.1', 'console_scripts',
> 'sip-build')())
> File "/usr/bin/sip-build", line 25, in importlib_load_entry_point
> return next(matches).load()
> StopIteration
> make[2]: ***
> [python/CMakeFiles/python_module_qgis__core.dir/build.make:765:
> python/core/build/_core/sip_corepart0.cpp] Error 1
> make[1]: *** [CMakeFiles/Makefile2:9159:
> python/CMakeFiles/python_module_qgis__core.dir/all] Error 2
> make: *** [Makefile:166: all] Error 2
> Donovan
