[QGIS-Developer] Time for db manager to become an "opt-in" plugin?
SIGéal sigeal at sigeal.com
Sat Jul 9 23:26:15 PDT 2022
Hello,
I fully support that -1
I submitted a feature request some weeks ago to suggest that Explorer
SQL functionalities should work on a non modal way :
https://github.com/qgis/QGIS/issues/49091
Christophe Damour
Le 10/07/2022 à 03:02, Alexandre Neto via QGIS-Developer a écrit :
> Hello all,
> -1 for me
> I am big QGIS/PostGIS user and DB manager in QGIS allows me to do
> something that you can't do elsewhere, run long spatial analysis using
> SQL.
> I understand the development reasons for removing db manager from the
> official release and I really enjoy all the effort that Alessandro put
> to bring most functionality to the browser. Nevertheless, I don't
> think it fully replaces db manager querying functionality, and I
> really don't think it will ever do.
> The execute SQL dialog is great and amazingly fast, but it doesn't
> replace the db manager editor. The QGIS SQL Editor (db manager or not)
> needs to be an independent window that one can keep open for as long
> as needed to develop and run queries step by step, see the results,
> load them in the project, re-run etc... Also, it is almost mandatory
> that the user, while having the SQL script open, can check tables
> details, like column names, preview their values, etc... to help write
> the queries. We need an independent window or in the limit a panel to
> allow that together with the browser panel.
> This db manager functionality is unique, and is (in my opinion) one of
> the reasons why QGIS is PostGIS de facto client.
> There are other minor functionality that is still not present, but can
> be added later, like being able to create and manage constraints. Or
> easily create a view from a query.
> I understand that for now the functionality I miss would be available
> as an external plugin, but, not being in core, soon it will just stop
> working, and no one will care. QGIS was born as PostGIS query and
> visualiser client, in my humble opinion, by removing db manager at
> these stage we are downgrading QGIS functionality.
> Thanks,
> Alexandre Neto
> A sexta, 8/07/2022, 18:12, Paolo Cavallini via QGIS-Developer
> <qgis-developer at lists.osgeo.org> escreveu:
>     Hi all,
>     are we going to implement this? Apparently nobody objects.
>     I'd add to the list the Topology sub plugin by strk. Probably not
>     widely
>     used, but an unique feature.
>     I confirm that in the meantime the table historicization has been
>     broken, one more reason for not shipping DB Manager in the current
>     state.
>     Cheers.
>     Il 22/06/22 07:55, Nyall Dawson ha scritto:
>     > - Saving/re-running previously saved SQL queries
>     very useful to me. also loading the result of a query as a new layer
>     > - Switching to the simplified "SQL builder" dialog for creating
>     a SQL query
>     > - Truncating a table (this is available through a Processing
>     > algorithm, just not via browser)
>     > - Attribute index creation (this is available through a Processing
>     handy but not crucial
>     > - !! Support for editing an existing column (changing
>     name/type). This
>     > is the biggest functionality gap -- changing existing column
>     types is
>     > not available elsewhere in QGIS
>     > - Listing database triggers
>     I'd add storicization of a table - I couldn't find anything easier
>     for this.
>     Cheers.
>     Paolo Cavallini
>     www.faunalia.eu <http://www.faunalia.eu> - QGIS.org
>     training, support, development on QGIS, PostGIS and more
>     _______________________________________________
>     QGIS-Developer mailing list
>     QGIS-Developer at lists.osgeo.org
>     List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>     Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> List info:https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20220710/08aeb046/attachment.htm>
More information about the QGIS-Developer mailing list
