[QGIS-Developer] Overlay expression function without a current object
Stefan Giese (WhereGroup)
stefan.giese at wheregroup.com
Wed Jul 13 02:54:52 PDT 2022
Hi Andreas,
you can use the aggregate function for this, something like:
aggregate(layer:='layer1',
aggregate:='concatenate',
expression:="name",
filter:=intersects(
map_get( item_variables( 'Karte 1'), 'map_extent_center' ),
$geometry),
concatenator:=',')
and no need to build a point with make_point, the item variable
map_extent_center is already a point.
Best regards
Stefan
Am 13.07.2022 um 09:33 schrieb Andreas Neumann via QGIS-Developer:
> Hi,
> I would like to use the "overlay_within" expression function, but in
> layout context - and in this case I dont have a "current_feature".
> The goal is to find out the municipality from the map center of my
> main map in the layout (but not in atlas context).
> What I tried:
> with_variable(
> 'current_geometry',
> make_point(
> x( map_get( item_variables( 'Hauptkarte'), 'map_extent_center' ) ),
> y( map_get( item_variables( 'Hauptkarte'), 'map_extent_center' ) )
> overlay_within(
> layer:='Gemeindegrenzen',
> expression:=gemeindename
> But apparently the "overlay_within" geometry function needs a
> "$currentfeature" - which I don't have, but could create artificially
> with make_point from the map center.
> Is there any way to "artificially" create a "$currentfeature", so that
> my overlay expression function would work?
> Thanks for any ideas,
> Andreas
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Mit freundlichen Grüßen
Stefan Giese
Projektleiter/Consultant
Aufwind durch Wissen!
Jetzt neu: Web-Seminare und Online-Schulungen
bei der www.foss-academy.com
WhereGroup GmbH
Schwimmbadstr. 2
79100 Freiburg
Germany
Tel.: +49 (0)761 / 519 102 - 61
Fax: +49 (0)761 / 519 102 - 11
www.wheregroup.com
Geschäftsführer:
Olaf Knopp, Peter Stamm
Amtsgericht Bonn, HRB 9885
