[QGIS-Developer] Overlay expression function without a current object
Andreas Neumann a.neumann at carto.net
Wed Jul 13 00:33:43 PDT 2022
I would like to use the "overlay_within" expression function, but in
layout context - and in this case I dont have a "current_feature".
The goal is to find out the municipality from the map center of my main
map in the layout (but not in atlas context).
What I tried:
with_variable(
   'current_geometry',
   make_point(
     x( map_get( item_variables( 'Hauptkarte'), 'map_extent_center' ) ),
     y( map_get( item_variables( 'Hauptkarte'), 'map_extent_center' ) )
   overlay_within(
     layer:='Gemeindegrenzen',
     expression:=gemeindename
But apparently the "overlay_within" geometry function needs a
"$currentfeature" - which I don't have, but could create artificially
with make_point from the map center.
Is there any way to "artificially" create a "$currentfeature", so that
my overlay expression function would work?
Thanks for any ideas,
Andreas
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20220713/efce599b/attachment.htm>
More information about the QGIS-Developer mailing list
