[QGIS-Developer] Qgis server: terrible performance with Qgis 3.26
David Marteau
dmarteau at 3liz.com
Tue Jun 21 03:27:38 PDT 2022
May be I could use QgsRuntimeProfiler output in first place ?
Le 20/06/2022 à 18:55, Even Rouault a écrit :
> Use sysprof or just run under a debugger and interrupt regularly
> should help you spot in which method(s) most time is spent
> Le 20/06/2022 à 18:48, David Marteau via QGIS-Developer a écrit :
>> I used the following test:
>> readflags = Qgis.ProjectReadFlags() readflags |=
>> Qgis.ProjectReadFlag.TrustLayerMetadata|Qgis.ProjectReadFlag.DontLoad3DViews|Qgis.ProjectReadFlag.DontLoadProjectStyles
>> prj = QgsProject()%timeit -n 1
>> prj.read(f"{datapath}/france_parts3_26.qgs",readflags)
>> 105 ms ± 18.5 ms per loop (mean ± std. dev. of 7 runs, 1 loop each)
>> This improve the result but we are still much higher that the
>> loading time of 3.24: 15ms compared to 105ms
>> Le 20/06/2022 à 18:38, Nyall Dawson a écrit :
>>> On Mon, 20 June 2022, 11:42 pm David Marteau, <dmarteau at 3liz.com> wrote:
>>> Hi,
>>> > You should set the other new read optimisation flags here --
>>> see
>>> https://github.com/qgis/QGIS/blob/88ebb3f2f513dbce5a775f50e51ea0117f859c65/src/core/qgis.h#L1962
>>> These are already available also in 3.24 and we use the
>>> `TrustLayerMetadata` in the above test. For server, the other
>>> flags are not applicable (Getprint requests need print layouts ).
>>> So that mean we are comparing 3.24 to 3.26 with same level of
>>> read optimisation and that does not change the fact that, for
>>> that very same level of read optimisation, project's loading is
>>> incredibly slower in 3.26.
>>> You'll need to set the new flags relating to skipping the 3d views
>>> and project style loading in order to compare properly. Neither of
>>> those things were occurring in 3.24, and both have an associated
>>> cost. And neither are relevant for server.
>>> Nyall
>>> Le 20/06/2022 à 15:10, Nyall Dawson a écrit :
>>>> On Mon, 20 June 2022, 9:37 pm David Marteau via QGIS-Developer,
>>>> <qgis-developer at lists.osgeo.org> wrote:
>>>> Hi,
>>>> I have noticed a huge drop of performance while testing
>>>> Qgis server with Qgis 3.26, from 10x to 30x slower as usual.
>>>> Trying to reduce the problem I have found a huge increase
>>>> of time spend reading the project in 3.26 compared to 3.24.
>>>> Here some benchmark with very simple project from the test
>>>> data set. Note: the project has been updated with qgis 3.26:
>>>> Qgis 3.24:
>>>> readflags = QgsProject.ReadFlags()readflags |=
>>>> QgsProject.FlagTrustLayerMetadata
>>>> prj = QgsProject()
>>>> %timeit -n 1 prj.read(f"{datapath}/france_parts.qgs",readflags)
>>>> > 15.7 ms ± 205 µs per loop (mean ± std. dev. of 7 runs, 1 loop each)
>>>> Qgis 3.26:
>>>> readflags = QgsProject.ReadFlags() readflags |=
>>>> see
>>>> Nyall
>>>> prj = QgsProject()
>>>> 195 ms ± 44 ms per loop (mean ± std. dev. of 7 runs, 1 loop each)
>>>> There is a factor x10 between Qgis 3.24 et Qgis 3.26 for
>>>> the exact same project.
>>>> This has serious impact on requests: landing page catalog
>>>> request time increased from approximatevely 110ms to more
>>>> than 3.0s with our test data set.
>>>> David Marteau
>>>> www.3liz.com <http://www.3liz.com>
>>>> _______________________________________________
>>>> QGIS-Developer mailing list
>>>> QGIS-Developer at lists.osgeo.org
>>>> List info:
>>>> https://lists.osgeo.org/mailman/listinfo/qgis-developer
>>>> Unsubscribe:
>> List info:https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-developer
> http://www.spatialys.com
> My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20220621/f5431320/attachment-0001.htm>
