[QGIS-Developer] Override System Locale user interface with American English by Default?
DelazJ delazj at gmail.com
Thu Mar 24 04:52:07 PDT 2022
I'm sure I'm not a particular case: when I'm asked to select a language, I
usually look after the one I'm the most comfortable with and select it. And
in this case, I guess most of pt_PT people seeing their language in the
list will still pick that language, ignoring there are issues with it.
Mathieu there's already a value check: only languages with 35% are pulled
into code base. The issue here is that pt_PT has issues with the quality of
the translated strings.
Regards,
Harrissou
Le jeu. 24 mars 2022 à 12:39, Mathieu Pellerin via QGIS-Developer <
qgis-developer at lists.osgeo.org> a écrit :
> Could we not have some means to attach a quality value to each language
> (eg at the very least % translated), and only force English on poorly
> translated languages? I feel forcing English by default would be a
> disservice to the part of the community that spends hours to translate QGIS.
> On Thu, Mar 24, 2022, 18:32 Alexandre Neto via QGIS-Developer <
> qgis-developer at lists.osgeo.org> wrote:
>> Hi Alessandro,
>> Well, the option on first launch would be a much bettter solution. But
>> probably more complicated. Any idea of how much man/hours would be needed
>> to implement it?
>> Thanks,
>> Alex
>> A quinta, 24/03/2022, 11:21, Alessandro Pasotti <apasotti at gmail.com>
>> escreveu:
>>> Hi Alexandre,
>>> it seems reasonable to me but I'd suggest adding a first-time notice and
>>> an option for the user to actually set the system locale, maybe only for
>>> the first QGIS launch.
>>> On Thu, Mar 24, 2022 at 12:12 PM Alexandre Neto via QGIS-Developer <
>>>> Hi,
>>>> I have raised this before, but I wanted to ask for it again. Currently,
>>>> QGIS default is not to Override System Locale and use the system's locale
>>>> for User interface.
>>>> If the system locale language happens to have good and reliable
>>>> translations, this works well, but when the language is incomplete or
>>>> poorly translated, this IMHO poses a problem.
>>>> The European Portuguese translation is quite poor, with many errors and
>>>> bad translations. In the end it is sometimes hard to work with the GUI in
>>>> PT_pt. To me the bad thing is it looks bad on the project reputation and
>>>> people (users) read it as a symptom of bad quality software, which is not
>>>> the case.
>>>> So, I wanted to suggest if we could have American english as the
>>>> default for the GUI? Would this  be reasonable?
>>>> Thanks,
>>>> Alexandre Neto
>>>> _______________________________________________
>>>> QGIS-Developer mailing list
>>>> QGIS-Developer at lists.osgeo.org
>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>>> Alessandro Pasotti
>>> QCooperative:  www.qcooperative.net
>>> ItOpen:   www.itopen.it
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20220324/12768a42/attachment.html>
More information about the QGIS-Developer mailing list
