[QGIS-Developer] Override System Locale user interface with American English by Default?
Mathieu Pellerin
nirvn.asia at gmail.com
Thu Mar 24 05:10:50 PDT 2022
I'm aware of the 35% pull threshold. I was suggesting we could raise the
bar to eg 80% for that language to be set as default on first launch :)
On Thu, Mar 24, 2022, 18:52 DelazJ <delazj at gmail.com> wrote:
> Hi,
> I'm sure I'm not a particular case: when I'm asked to select a language, I
> usually look after the one I'm the most comfortable with and select it. And
> in this case, I guess most of pt_PT people seeing their language in the
> list will still pick that language, ignoring there are issues with it.
> Mathieu there's already a value check: only languages with 35% are pulled
> into code base. The issue here is that pt_PT has issues with the quality of
> the translated strings.
> Regards,
> Harrissou
> Le jeu. 24 mars 2022 à 12:39, Mathieu Pellerin via QGIS-Developer <
> qgis-developer at lists.osgeo.org> a écrit :
>> Could we not have some means to attach a quality value to each language
>> (eg at the very least % translated), and only force English on poorly
>> translated languages? I feel forcing English by default would be a
>> disservice to the part of the community that spends hours to translate QGIS.
>> On Thu, Mar 24, 2022, 18:32 Alexandre Neto via QGIS-Developer <
>> qgis-developer at lists.osgeo.org> wrote:
>>> Hi Alessandro,
>>> Well, the option on first launch would be a much bettter solution. But
>>> probably more complicated. Any idea of how much man/hours would be needed
>>> to implement it?
>>> Thanks,
>>> Alex
>>> A quinta, 24/03/2022, 11:21, Alessandro Pasotti <apasotti at gmail.com>
>>> escreveu:
>>>> Hi Alexandre,
>>>> it seems reasonable to me but I'd suggest adding a first-time notice
>>>> and an option for the user to actually set the system locale, maybe only
>>>> for the first QGIS launch.
>>>> On Thu, Mar 24, 2022 at 12:12 PM Alexandre Neto via QGIS-Developer <
>>>>> Hi,
>>>>> I have raised this before, but I wanted to ask for it again.
>>>>> Currently, QGIS default is not to Override System Locale and use the
>>>>> system's locale for User interface.
>>>>> If the system locale language happens to have good and reliable
>>>>> translations, this works well, but when the language is incomplete or
>>>>> poorly translated, this IMHO poses a problem.
>>>>> The European Portuguese translation is quite poor, with many errors
>>>>> and bad translations. In the end it is sometimes hard to work with the GUI
>>>>> in PT_pt. To me the bad thing is it looks bad on the project reputation and
>>>>> people (users) read it as a symptom of bad quality software, which is not
>>>>> the case.
>>>>> So, I wanted to suggest if we could have American english as the
>>>>> default for the GUI? Would this be reasonable?
>>>>> Thanks,
>>>>> Alexandre Neto
>>>>> _______________________________________________
>>>>> QGIS-Developer mailing list
>>>>> QGIS-Developer at lists.osgeo.org
>>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>>>> Alessandro Pasotti
>>>> QCooperative: www.qcooperative.net
>>>> ItOpen: www.itopen.it
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20220324/20bba946/attachment.html>
