[QGIS-Developer] QGIS-Documentation fails to build
DelazJ
delazj at gmail.com
Tue May 3 02:35:18 PDT 2022
Hi devs,
The "doctest" workflow in QGIS-Documentation repository is again broken. We
are getting a segmentation fault [0]. This might have begun at least 5 days
ago, only on master branch. The 3.22 doctest passes.
If someone can give it a look, it will be much appreciated. Thanks.
Regards,
Harrissou
[0]
https://github.com/qgis/QGIS-Documentation/runs/6270691298?check_suite_focus=true#step:6:542
Le mar. 8 juin 2021 à 22:02, Delaz J <delazj at gmail.com> a écrit :
> Thanks Alessandro,
> I'd say from June 1st or May 31st.
> Regards,
> Harrissou
> Le 08/06/2021 à 18:58, Alessandro Pasotti a écrit :
> Hi,
> I'll have a look tomorrow, since when did it start failing?
> On Tue, Jun 8, 2021 at 5:06 PM DelazJ <delazj at gmail.com> wrote:
>> Hi devs,
>> still me looking for help to fix the QGIS-Documentation doctest workflow
>> taking hours and getting canceled
>> https://github.com/qgis/QGIS-Documentation/actions/workflows/doctest.yml
>> Thanks,
>> Harrissou
>> Le mar. 1 juin 2021 à 08:23, Delaz J <delazj at gmail.com> a écrit :
>>> Hi,
>>> The doctest is again failing, actually aborted by GitHub after 6 hours
>>> (it used to take <5mn). Began yesterday.
>>> From what I can see, it's struggling to connect and download to the qgis
>>> docker image. See
>>> https://github.com/qgis/QGIS-Documentation/runs/2715733455?check_suite_focus=true
>>> vs
>>> https://github.com/qgis/QGIS-Documentation/runs/2709502529?check_suite_focus=true
>>> Any help appreciated.
>>> Thanks,
>>> Harrissou
>>> Le 28/05/2021 à 11:03, DelazJ a écrit :
>>> Hi,
>>> Thanks Alessandro. Fixed now.
>>> Harrissou
>>> Le mer. 26 mai 2021 à 15:48, Alessandro Pasotti <apasotti at gmail.com> a
>>> écrit :
>>>> It has been moved to the parent class QgsMapLayer
>>>> On Wed, May 26, 2021 at 3:32 PM DelazJ <delazj at gmail.com> wrote:
>>>>> Hi devs,
>>>>> QGIS-Documentation build test is failing due to "WARNING: py:meth
>>>>> reference target not found: qgis.core.QgsVectorLayer.setDataSource" [0]
>>>>> It looks like the QgsVectorLayer.setDataSource method is no longer
>>>>> available in master. Anyone knows what is the replacement?
>>>>> Thanks,
>>>>> Harrissou
>>>>> [0]
>>>>> https://github.com/qgis/QGIS-Documentation/runs/2672228415?check_suite_focus=true#step:5:622
>>>>> _______________________________________________
>>>>> QGIS-Developer mailing list
>>>>> QGIS-Developer at lists.osgeo.org
>>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>>>> Alessandro Pasotti
>>>> QCooperative: www.qcooperative.net
>>>> ItOpen: www.itopen.it
> Alessandro Pasotti
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20220503/d79538e0/attachment.htm>
