[QGIS-Developer] QGIS-Documentation fails to build
Alessandro Pasotti
apasotti at gmail.com
Thu May 19 03:09:05 PDT 2022
I cannot make promises, but if I'm allowed to spend the paid bugfixing
hours to fix this I think I could have a look.
Cheers
On Thu, May 19, 2022 at 12:06 PM DelazJ via QGIS-Developer
<qgis-developer at lists.osgeo.org> wrote:
> Hi,
> well...
> For your information, I disabled the doctest github action, to stop getting annoyed by (unrelated) failure messages for each interaction with the repository.
> That also means no more checks for the PyQGIS Cookbook changes (which includes this recent pull request), until we get a fix.
> Greetings,
> Harrissou
> Le lun. 9 mai 2022 à 16:35, DelazJ <delazj at gmail.com> a écrit :
>> Hi,
>> Thanks again Richard for testing.
>> Any chance someone else gives it a look, please? Thanks.
>> Regards,
>> Harrissou
>> Le mar. 3 mai 2022 à 20:44, Richard Duivenvoorde via QGIS-Developer <qgis-developer at lists.osgeo.org> a écrit :
>>> On 5/3/22 11:35, DelazJ via QGIS-Developer wrote:
>>> > Hi devs,
>>> > The "doctest" workflow in QGIS-Documentation repository is again broken. We are getting a segmentation fault [0]. This might have begun at least 5 days ago, only on master branch. The 3.22 doctest passes.
>>> > If someone can give it a look, it will be much appreciated. Thanks.
>>> Hi Harrissou,
>>> I tried looking into it...
>>> A normal local build is fine... (so in a VENV with the REQUIREMENTS.txt of QGIS-Website, calling "make html")
>>> But that does not build the doc tests (the python code in the cookbook is tested in that)
>>> Then I tried on my local machine, what I see in the CI log:
>>> make -f docker.mk doctest
>>> and that fails with exact the same messages, except it looks like it crashes on random parts of the cookbook tests
>>> @devs can anybody of you make something from the stacktrace?
>>> SIP related?
>>> Missing dependency?
>>> Any hints appreciated
>>> Regards,
>>> QGIS-Developer mailing list
>>> QGIS-Developer at lists.osgeo.org
>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Alessandro Pasotti
QCooperative: www.qcooperative.net
ItOpen: www.itopen.it
