[QGIS-Developer] QGIS-Documentation fails to build
DelazJ delazj at gmail.com
Thu May 19 03:05:55 PDT 2022
well...
For your information, I disabled the doctest github action
<https://github.com/qgis/QGIS-Documentation/actions/workflows/doctest.yml>,
to stop getting annoyed by (unrelated) failure messages for each
interaction with the repository.
That also means no more checks for the PyQGIS Cookbook changes (which
includes this recent pull request
<https://github.com/qgis/QGIS-Documentation/pull/7559>), until we get a fix.
Greetings,
Harrissou
Le lun. 9 mai 2022 à 16:35, DelazJ <delazj at gmail.com> a écrit :
> Hi,
> Thanks again Richard for testing.
> Any chance someone else gives it a look, please? Thanks.
> Regards,
> Harrissou
> Le mar. 3 mai 2022 à 20:44, Richard Duivenvoorde via QGIS-Developer <
> qgis-developer at lists.osgeo.org> a écrit :
>> On 5/3/22 11:35, DelazJ via QGIS-Developer wrote:
>> > Hi devs,
>> > The "doctest" workflow in QGIS-Documentation repository is again
>> broken. We are getting a segmentation fault [0]. This might have begun at
>> least 5 days ago, only on master branch. The 3.22 doctest passes.
>> > If someone can give it a look, it will be much appreciated. Thanks.
>> Hi Harrissou,
>> I tried looking into it...
>> A normal local build is fine... (so in a VENV with the REQUIREMENTS.txt
>> of QGIS-Website, calling "make html")
>> But that does not build the doc tests (the python code in the cookbook is
>> tested in that)
>> Then  I tried on my local machine, what I see in the CI log:
>> make -f docker.mk doctest
>> and that fails with exact the same messages, except it looks like it
>> crashes on random parts of the cookbook tests
>> @devs can anybody of you make something from the stacktrace?
>> SIP related?
>> Missing dependency?
>> Any hints appreciated
>> Regards,
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20220519/4b050e9d/attachment.htm>
More information about the QGIS-Developer mailing list
