[QGIS-Developer] QGIS-Documentation fails to build
DelazJ delazj at gmail.com
Mon May 9 07:35:56 PDT 2022
Thanks again Richard for testing.
Any chance someone else gives it a look, please? Thanks.
Regards,
Harrissou
Le mar. 3 mai 2022 à 20:44, Richard Duivenvoorde via QGIS-Developer <
qgis-developer at lists.osgeo.org> a écrit :
> On 5/3/22 11:35, DelazJ via QGIS-Developer wrote:
> > Hi devs,
> > The "doctest" workflow in QGIS-Documentation repository is again broken.
> We are getting a segmentation fault [0]. This might have begun at least 5
> days ago, only on master branch. The 3.22 doctest passes.
> > If someone can give it a look, it will be much appreciated. Thanks.
> Hi Harrissou,
> I tried looking into it...
> A normal local build is fine... (so in a VENV with the REQUIREMENTS.txt of
> QGIS-Website, calling "make html")
> But that does not build the doc tests (the python code in the cookbook is
> tested in that)
> Then  I tried on my local machine, what I see in the CI log:
> make -f docker.mk doctest
> and that fails with exact the same messages, except it looks like it
> crashes on random parts of the cookbook tests
> @devs can anybody of you make something from the stacktrace?
> SIP related?
> Missing dependency?
> Any hints appreciated
> Regards,
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20220509/f6aa4e33/attachment.htm>
More information about the QGIS-Developer mailing list
