[QGIS-Developer] Issue with qgis Docker images starting from qgis:final-3_22_10
DelazJ
delazj at gmail.com
Mon Nov 7 02:47:02 PST 2022
I also confirm this issue for the QGIS 3.22 documentation (
https://github.com/qgis/QGIS-Documentation/issues/7858) but afaict, tests
were still passing mid october (hence with 3.22.11).
Regards,
Harrissou
Le lun. 7 nov. 2022 à 11:15, Paolo Tormene via QGIS-Developer <
qgis-developer at lists.osgeo.org> a écrit :
> Hello. I use qgis docker images to run tests for a plugin. Recently my
> tests started to fail when attempting to import qgis ("ModuleNotFoundError:
> No module named 'qgis'").
> I normally run tests using images qgis/qgis:latest and
> qgis/qgis:release-3_22, in order to check compatibility with both the
> latest release and the current LTR.
> With qgis/qgis:latest everything works, but with qgis/qgis:release-3_22 it
> produces the error described above.
> While investigating the problem, I also tried to use older versions:
> qgis:final-3_22_12 -> KO
> qgis:final-3_22_11 -> KO
> qgis:final-3_22_10 -> KO
> qgis:final-3_22_9 -> OK (it seems to work as expected until this version)
> Were there any significant changes between 3_22_9 and 3_22_10 that might
> have caused this? Do you have any suggestions?
> Thank you,
> Paolo
> *PAOLO TORMENE* senior software developer +39 0382 5169882
> *GLOBAL EARTHQUAKE MODEL * working together to assess risk
> *GEM -* globalquakemodel.org <http://www.globalquakemodel.org> *T -*
> @GEMwrld <http://twitter.com/GEMwrld> *F -* GEMwrld
> <http://www.facebook.com/GEMwrld>
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20221107/98ba269b/attachment.htm>
