[QGIS-Developer] Issue with qgis Docker images starting from qgis:final-3_22_10
Etienne Trimaille
etienne.trimaille at gmail.com
Wed Nov 9 05:18:27 PST 2022
Thanks for raising this issue.
I can also confirm the regression in unit testing plugins with QGIS 3.22
with QGIS docker images.
With the tag qgis/qgis:final-3_22_9 and different branches such as 3.16,
3.28, master, everything works fine.
Starting with qgis/qgis:final-3_22_10, tests are not loaded anymore :
Running test tests.runner.test_package ...
ERROR: no output from the test runner! (exit code: 0)
I didn't check if it was also linked to a ModuleNotFoundError under the
hood.
Regards
Le lun. 7 nov. 2022 à 11:47, DelazJ via QGIS-Developer <
qgis-developer at lists.osgeo.org> a écrit :
> Hi,
> I also confirm this issue for the QGIS 3.22 documentation (
> https://github.com/qgis/QGIS-Documentation/issues/7858) but afaict, tests
> were still passing mid october (hence with 3.22.11).
> Regards,
> Harrissou
> Le lun. 7 nov. 2022 à 11:15, Paolo Tormene via QGIS-Developer <
>> Hello. I use qgis docker images to run tests for a plugin. Recently my
>> tests started to fail when attempting to import qgis ("ModuleNotFoundError:
>> No module named 'qgis'").
>> I normally run tests using images qgis/qgis:latest and
>> qgis/qgis:release-3_22, in order to check compatibility with both the
>> latest release and the current LTR.
>> With qgis/qgis:latest everything works, but with qgis/qgis:release-3_22
>> it produces the error described above.
>> While investigating the problem, I also tried to use older versions:
>> qgis:final-3_22_12 -> KO
>> qgis:final-3_22_11 -> KO
>> qgis:final-3_22_10 -> KO
>> qgis:final-3_22_9 -> OK (it seems to work as expected until this version)
>> Were there any significant changes between 3_22_9 and 3_22_10 that might
>> have caused this? Do you have any suggestions?
>> Thank you,
>> Paolo
>> *PAOLO TORMENE* senior software developer +39 0382 5169882
>> *GLOBAL EARTHQUAKE MODEL * working together to assess risk
>> *GEM -* globalquakemodel.org <http://www.globalquakemodel.org> *T -*
>> @GEMwrld <http://twitter.com/GEMwrld> *F -* GEMwrld
>> <http://www.facebook.com/GEMwrld>
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20221109/03ec142c/attachment.htm>
