[QGIS-Developer] QGIS python action with Expression problem
Alessandro Pasotti apasotti at gmail.com
Mon Nov 7 04:32:20 PST 2022
On Mon, Nov 7, 2022 at 11:59 AM Andreas Neumann <a.neumann at carto.net> wrote:
> Hi Ale,
> Thanks for the hint!
You're welcome!
the formScope adds another feature: the "form" feature which
represents a virtual feature with the values taken from the current
form status.
> With
> expContext.setFeature(form.feature())
> it seems to work.
> I was assuming that adding the formScope would also add the feature context ... but apparently not.
> Now I can continue adding the more complex expression.
> Thank you for your help!
> Andreas
> On 2022-11-07 11:46, Alessandro Pasotti wrote:
> You need to set the feature if you want to access the feature fields.
> QgsExpressionContext::setFeature( const QgsFeature &feature )
> If you want the form feature values you need to use the current_value
> or the current_feature functions.
> Regards.
> On Mon, Nov 7, 2022 at 11:27 AM Andreas Neumann via QGIS-Developer
> <qgis-developer at lists.osgeo.org> wrote:
> Hi,
> I am trying to implement a Python action in "form" and "feature" action scope that uses a QGIS expression, but fail to get a valid expression calculation.
> Here is my code so far:
> from qgis.PyQt.QtWidgets import *
> from qgis.core import QgsMessageLog
> expContext = QgsExpressionContext()
> expContext.appendScopes(QgsExpressionContextUtils.globalProjectLayerScopes(form.layer()))
> expContext.appendScope(QgsExpressionContextUtils.formScope(form.feature(),'SingleEditMode'))
> exp = QgsExpression('t_id')
> expResult = exp.evaluate(expContext)
> QgsMessageLog.logMessage('Expression Result=' + str(expResult))
> So even the most basic expression (getting a field value) will not work in my code. I always get "None" as a result.
> Any idea what is missing? Am I missing a certain scope or an import statement?
> Thank you very much for any hints what might be wrong here ...
> Andreas
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Alessandro Pasotti
QCooperative:  www.qcooperative.net
ItOpen:   www.itopen.it
More information about the QGIS-Developer mailing list
