[QGIS-Developer] QGIS attribute form - changing values with Python of disabled widgets
Andreas Neumann a.neumann at carto.net
Mon Nov 7 06:42:43 PST 2022
I have a QGIS form with a number of widgets that are set to "disabled".
I don't want the user to change these values manually, but they should
be updated by a Python action "on demand". Hence I set the editable
state of these widgets to False.
Now I noticed that while I can change values in the widgets with my
Python action, the values are not stored when the editable state is set
to "False". As soon as I set the editable state to "True", then my
Python action works fine and the values are correctly stored.
I tried with two approaches:
QgsAttributeForm.changeAttribute()
and
QgsWidget.setValue()
Both of these work fine when editable state is enabled, but not, when
they are disabled.
Is there any way to also change attribute values when the editable state
of a widget is set to False?
Thanks,
Andreas
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20221107/23580538/attachment-0001.htm>
More information about the QGIS-Developer mailing list
