[QGIS-Developer] QGIS attribute form - changing values with Python of disabled widgets
Matthias Kuhn matthias at opengis.ch
Mon Nov 7 06:46:08 PST 2022
Hi Andreas,
How about going the other way around and leaving them as editable in the
config and disabling the widget via python instead?
Matthias
On Mon, Nov 7, 2022 at 3:42 PM Andreas Neumann via QGIS-Developer <
qgis-developer at lists.osgeo.org> wrote:
> Hi,
> I have a QGIS form with a number of widgets that are set to "disabled". I
> don't want the user to change these values manually, but they should be
> updated by a Python action "on demand". Hence I set the editable state of
> these widgets to False.
> Now I noticed that while I can change values in the widgets with my Python
> action, the values are not stored when the editable state is set to
> "False". As soon as I set the editable state to "True", then my Python
> action works fine and the values are correctly stored.
> I tried with two approaches:
> QgsAttributeForm.changeAttribute()
> and
> QgsWidget.setValue()
> Both of these work fine when editable state is enabled, but not, when they
> are disabled.
> Is there any way to also change attribute values when the editable state
> of a widget is set to False?
> Thanks,
> Andreas
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
<https://www.opengis.ch/2022/11/03/best-of-swiss-enterprise-app-award-for-qfield/>
Best of Swiss Enterprise App-Award for QField
- Hold the power of QGIS in your hand - get it now <https://qfield.org/get>
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20221107/99ca86f0/attachment.htm>
More information about the QGIS-Developer mailing list
