[QGIS-Developer] Issue with qgis Docker images starting from qgis:final-3_22_10
Nicolas Godet
nicolas.godet at outlook.fr
Wed Nov 9 08:39:54 PST 2022
Is this the same issue as described here https://github.com/qgis/QGIS/issues/50729 ?
Le 9 nov. 2022 à 14:30, Sergio Alexander Ramírez Navarro via QGIS-Developer <qgis-developer at lists.osgeo.org> a écrit :
I found that since version 3_22_10 the plugins folder is no longer located in /usr/share/qgis/python/plugins but now in /qgis/python/plugins , this may have caused the issue.
Regards,
Sergio
El mié, 9 nov 2022 a la(s) 08:19, Etienne Trimaille via QGIS-Developer (qgis-developer at lists.osgeo.org<mailto:qgis-developer at lists.osgeo.org>) escribió:
Thanks for raising this issue.
I can also confirm the regression in unit testing plugins with QGIS 3.22 with QGIS docker images.
With the tag qgis/qgis:final-3_22_9 and different branches such as 3.16, 3.28, master, everything works fine.
Starting with qgis/qgis:final-3_22_10, tests are not loaded anymore :
Running test tests.runner.test_package ...
ERROR: no output from the test runner! (exit code: 0)
I didn't check if it was also linked to a ModuleNotFoundError under the hood.
Regards
Le lun. 7 nov. 2022 à 11:47, DelazJ via QGIS-Developer <qgis-developer at lists.osgeo.org<mailto:qgis-developer at lists.osgeo.org>> a écrit :
I also confirm this issue for the QGIS 3.22 documentation (https://github.com/qgis/QGIS-Documentation/issues/7858) but afaict, tests were still passing mid october (hence with 3.22.11).
Regards,
Harrissou
Le lun. 7 nov. 2022 à 11:15, Paolo Tormene via QGIS-Developer <qgis-developer at lists.osgeo.org<mailto:qgis-developer at lists.osgeo.org>> a écrit :
Hello. I use qgis docker images to run tests for a plugin. Recently my tests started to fail when attempting to import qgis ("ModuleNotFoundError: No module named 'qgis'").
I normally run tests using images qgis/qgis:latest and qgis/qgis:release-3_22, in order to check compatibility with both the latest release and the current LTR.
With qgis/qgis:latest everything works, but with qgis/qgis:release-3_22 it produces the error described above.
While investigating the problem, I also tried to use older versions:
qgis:final-3_22_12 -> KO
qgis:final-3_22_11 -> KO
qgis:final-3_22_10 -> KO
qgis:final-3_22_9 -> OK (it seems to work as expected until this version)
Were there any significant changes between 3_22_9 and 3_22_10 that might have caused this? Do you have any suggestions?
Thank you,
Paolo
PAOLO TORMENE senior software developer +39 0382 5169882
GLOBAL EARTHQUAKE MODEL working together to assess risk
GEM - globalquakemodel.org<http://www.globalquakemodel.org> T - @GEMwrld<http://twitter.com/GEMwrld> F - GEMwrld<http://www.facebook.com/GEMwrld>
QGIS-Developer mailing list
QGIS-Developer at lists.osgeo.org<mailto:QGIS-Developer at lists.osgeo.org>
List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20221109/6d1ad628/attachment-0001.htm>
