[QGIS-Developer] Issue with qgis Docker images starting from qgis:final-3_22_10
Etienne Trimaille etienne.trimaille at gmail.com
Wed Nov 9 09:06:18 PST 2022
Yes it is. Thanks for linking to an existing ticket.
By the way, as we are quite a few using this image for testing QGIS plugin,
does anyone have some plans to make a smaller docker image for testing
plugins ? (It's nearly 9gb right now).
Le mer. 9 nov. 2022 à 17:39, Nicolas Godet <nicolas.godet at outlook.fr> a
écrit :
> Hi,
> Is this the same issue as described here
> https://github.com/qgis/QGIS/issues/50729 ?
> Le 9 nov. 2022 à 14:30, Sergio Alexander Ramírez Navarro via
> QGIS-Developer <qgis-developer at lists.osgeo.org> a écrit :
> I found that since version 3_22_10 the plugins folder is no longer located
> in /usr/share/qgis/python/plugins but now in /qgis/python/plugins , this
> may have caused the issue.
> Regards,
> Sergio
> El mié, 9 nov 2022 a la(s) 08:19, Etienne Trimaille via QGIS-Developer (
> qgis-developer at lists.osgeo.org) escribió:
>> Thanks for raising this issue.
>> I can also confirm the regression in unit testing plugins with QGIS 3.22
>> with QGIS docker images.
>> With the tag qgis/qgis:final-3_22_9 and different branches such as 3.16,
>> 3.28, master, everything works fine.
>> Starting with qgis/qgis:final-3_22_10, tests are not loaded anymore :
>> Running test tests.runner.test_package ...
>> ERROR: no output from the test runner! (exit code: 0)
>> I didn't check if it was also linked to a ModuleNotFoundError under the
>> hood.
>> Regards
>> Le lun. 7 nov. 2022 à 11:47, DelazJ via QGIS-Developer <
>>> Hi,
>>> I also confirm this issue for the QGIS 3.22 documentation (
>>> https://github.com/qgis/QGIS-Documentation/issues/7858) but afaict,
>>> tests were still passing mid october (hence with 3.22.11).
>>> Regards,
>>> Harrissou
>>> Le lun. 7 nov. 2022 à 11:15, Paolo Tormene via QGIS-Developer <
>>>> Hello. I use qgis docker images to run tests for a plugin. Recently my
>>>> tests started to fail when attempting to import qgis ("ModuleNotFoundError:
>>>> No module named 'qgis'").
>>>> I normally run tests using images qgis/qgis:latest and
>>>> qgis/qgis:release-3_22, in order to check compatibility with both the
>>>> latest release and the current LTR.
>>>> With qgis/qgis:latest everything works, but with qgis/qgis:release-3_22
>>>> it produces the error described above.
>>>> While investigating the problem, I also tried to use older versions:
>>>> qgis:final-3_22_12 -> KO
>>>> qgis:final-3_22_11 -> KO
>>>> qgis:final-3_22_10 -> KO
>>>> qgis:final-3_22_9 -> OK (it seems to work as expected until this
>>>> version)
>>>> Were there any significant changes between 3_22_9 and 3_22_10 that
>>>> might have caused this? Do you have any suggestions?
>>>> Thank you,
>>>> Paolo
>>>> *PAOLO TORMENE* senior software developer +39 0382 5169882
>>>> *GLOBAL EARTHQUAKE MODEL *working together to assess risk
>>>> *GEM -* globalquakemodel.org <http://www.globalquakemodel.org> *T -*
>>>> @GEMwrld <http://twitter.com/GEMwrld> *F -* GEMwrld
>>>> <http://www.facebook.com/GEMwrld>
>>>> _______________________________________________
>>>> QGIS-Developer mailing list
>>>> QGIS-Developer at lists.osgeo.org
>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20221109/e4014641/attachment.htm>
More information about the QGIS-Developer mailing list
