[QGIS-Developer] Issue with qgis Docker images starting from qgis:final-3_22_10
    Harrissou s.
    delazj at gmail.com
    Sat Nov 19 00:08:02 PST 2022
Any chance someone looks into this issue, please? Thanks.
And generally speaking, should the LTR branding not also concern the docker image we output? This 3.22 docker image is broken for weeks (or almost 2 months according to others)...
Regards,
Harrissou
Le mer. 9 nov. 2022 à 18:06, Etienne Trimaille via QGIS-Developer <
qgis-developer at lists.osgeo.org> a écrit :
> Yes it is. Thanks for linking to an existing ticket.
> By the way, as we are quite a few using this image for testing QGIS
> plugin, does anyone have some plans to make a smaller docker image for
> testing plugins ? (It's nearly 9gb right now).
> Le mer. 9 nov. 2022 à 17:39, Nicolas Godet <nicolas.godet at outlook.fr> a
> écrit :
>> Hi,
>> Is this the same issue as described here
>> https://github.com/qgis/QGIS/issues/50729 ?
>> Le 9 nov. 2022 à 14:30, Sergio Alexander Ramírez Navarro via
>> QGIS-Developer <qgis-developer at lists.osgeo.org> a écrit :
>> I found that since version 3_22_10 the plugins folder is no longer
>> located in /usr/share/qgis/python/plugins but now in /qgis/python/plugins ,
>> this may have caused the issue.
>> Regards,
>> Sergio
>> El mié, 9 nov 2022 a la(s) 08:19, Etienne Trimaille via QGIS-Developer (
>> qgis-developer at lists.osgeo.org) escribió:
>>> Thanks for raising this issue.
>>> I can also confirm the regression in unit testing plugins with QGIS 3.22
>>> with QGIS docker images.
>>> With the tag qgis/qgis:final-3_22_9 and different branches such as 3.16,
>>> 3.28, master, everything works fine.
>>> Starting with qgis/qgis:final-3_22_10, tests are not loaded anymore :
>>> Running test tests.runner.test_package ...
>>> ERROR: no output from the test runner! (exit code: 0)
>>> I didn't check if it was also linked to a ModuleNotFoundError under the
>>> hood.
>>> Regards
>>> Le lun. 7 nov. 2022 à 11:47, DelazJ via QGIS-Developer <
>>>> Hi,
>>>> I also confirm this issue for the QGIS 3.22 documentation (
>>>> https://github.com/qgis/QGIS-Documentation/issues/7858) but afaict,
>>>> tests were still passing mid october (hence with 3.22.11).
>>>> Regards,
>>>> Harrissou
>>>> Le lun. 7 nov. 2022 à 11:15, Paolo Tormene via QGIS-Developer <
>>>>> Hello. I use qgis docker images to run tests for a plugin. Recently my
>>>>> tests started to fail when attempting to import qgis ("ModuleNotFoundError:
>>>>> No module named 'qgis'").
>>>>> I normally run tests using images qgis/qgis:latest and
>>>>> qgis/qgis:release-3_22, in order to check compatibility with both the
>>>>> latest release and the current LTR.
>>>>> With qgis/qgis:latest everything works, but with
>>>>> qgis/qgis:release-3_22 it produces the error described above.
>>>>> While investigating the problem, I also tried to use older versions:
>>>>> qgis:final-3_22_12 -> KO
>>>>> qgis:final-3_22_11 -> KO
>>>>> qgis:final-3_22_10 -> KO
>>>>> qgis:final-3_22_9 -> OK (it seems to work as expected until this
>>>>> version)
>>>>> Were there any significant changes between 3_22_9 and 3_22_10 that
>>>>> might have caused this? Do you have any suggestions?
>>>>> Thank you,
>>>>> Paolo
>>>>> *PAOLO TORMENE* senior software developer +39 0382 5169882
>>>>> *GLOBAL EARTHQUAKE MODEL *working together to assess risk
>>>>> *GEM -* globalquakemodel.org <http://www.globalquakemodel.org> *T -*
>>>>> @GEMwrld <http://twitter.com/GEMwrld> *F -* GEMwrld
>>>>> <http://www.facebook.com/GEMwrld>
>>>>> _______________________________________________
>>>>> QGIS-Developer mailing list
>>>>> QGIS-Developer at lists.osgeo.org
>>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20221119/eccaaad7/attachment.htm>
