[QGIS-Developer] pyqgis labelling settings
Hugh Kelley hghklly at gmail.com
Wed Nov 9 09:53:22 PST 2022
I finally found time to try this and it worked very well. Thank you!
one follow up question I have is that I can make the change visible by
running layer.triggerRepaint().
That does not refresh the values in the layer styling panel. I need select
a different layer and then select the original in order to see the changes
I've made in pyqgis. Is there a command that will refresh that pane?
On Sun, Oct 23, 2022 at 5:11 AM Francisco Puga <fpuga at icarto.es> wrote:
> This should work when working with SingleLabels
> layer = iface.activeLayer()
> settings = layer.labeling().settings()
> textFormat = settings.format()
> textFormat.setSize(20);
> settings.setFormat(textFormat)
> layer.labeling().setSettings(settings)
> hope it helps
> El vie, 21 oct 2022 a las 18:18, Hugh Kelley via QGIS-Developer
> (<qgis-developer at lists.osgeo.org>) escribió:
> > Hi,
> > I'm hoping to make some scripts for labelling layers.
> > I've found the basic labelling settings in
> >     layer =
> iface.activeLayer()layer.labeling().settings().format().size()
> > for example, and it seems that I could be able to update that with an
> object like
> >     newsize = QgsTextFormat()
> >     newsize.setSize(20)
> > but I haven't yet found the correct way to update the layer's value.
> > it seems like it needs to be passed an entire new `QgsPalLayerSettings`
> object but I haven't found a way to build a complete object.
> > I've seen `readFromLayer()` but I'm guessing that was a version 2 method
> that's no longer available in version 3.
> > any pointers or a simple piece of code for updating a layer labelling
> property would be hugely appreciated.
> > it also occurs to me to ask whether there is anything like:
> >     print(layer.renderer().symbol().symbolLayers()[0].properties())
> > that returns a dict of the layer symbology properties for a label.
> > Another helpful thing would be code that imports a label definition from
> an exported xml file.
> > thanks,
> > hugh
> > QGIS-Developer mailing list
> > QGIS-Developer at lists.osgeo.org
> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Francisco Puga
> iCarto | Innovación, Cooperación, Cartografía y Territorio S.L.
> https://icarto.es
> c/ Rafael Alberti nº 13 – 1º D
> 15008 A Coruña
> Galicia (Spain)
> +34 881927808
> Este correo electrónico contiene información estrictamente
> confidencial y es de uso exclusivo del destinatario, quedando
> prohibida a cualquier otra persona su revelación, copia, distribución,
> o el ejercicio de cualquier acción relativa a su contenido. Si ha
> recibido este mensaje por error, por favor conteste a su remitente
> mediante correo electrónico y proceda a borrarlo de su sistema.
> Sus datos personales serán tratados de forma confidencial y no serán
> cedidos a terceros ajenos a ICARTO. En cualquier caso, podrá ejercer
> los derecho de oposición, acceso, rectificación y cancelación de
> acuerdo con lo establecido en la Ley Orgánica 15/99, de 13 de
> diciembre, de Protección de Datos de Carácter Personal dirigiéndose a
> Innovación, Cooperación, Cartografía e Territorio, SL. (ICARTO) en la
> dirección postal a C/ Rafael Alberti, nº 13, 1ºD, 15.008 – (A Coruña).
Hugh Kelley
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20221109/820aeb2b/attachment.htm>
More information about the QGIS-Developer mailing list
