[QGIS-Developer] pyqgis labelling settings
Francisco Puga fpuga at icarto.es
Thu Nov 10 03:10:41 PST 2022
You can try
iface.layerTreeView().refreshLayerSymbology(layer.id())
El mié, 9 nov 2022 a las 18:53, Hugh Kelley (<hghklly at gmail.com>) escribió:
> I finally found time to try this and it worked very well. Thank you!
> one follow up question I have is that I can make the change visible by
> running layer.triggerRepaint().
> That does not refresh the values in the layer styling panel. I need select
> a different layer and then select the original in order to see the changes
> I've made in pyqgis. Is there a command that will refresh that pane?
> On Sun, Oct 23, 2022 at 5:11 AM Francisco Puga <fpuga at icarto.es> wrote:
>> This should work when working with SingleLabels
>> layer = iface.activeLayer()
>> settings = layer.labeling().settings()
>> textFormat = settings.format()
>> textFormat.setSize(20);
>> settings.setFormat(textFormat)
>> layer.labeling().setSettings(settings)
>> hope it helps
>> El vie, 21 oct 2022 a las 18:18, Hugh Kelley via QGIS-Developer
>> (<qgis-developer at lists.osgeo.org>) escribió:
>> > Hi,
>> > I'm hoping to make some scripts for labelling layers.
>> > I've found the basic labelling settings in
>> >     layer =
>> iface.activeLayer()layer.labeling().settings().format().size()
>> > for example, and it seems that I could be able to update that with an
>> object like
>> >     newsize = QgsTextFormat()
>> >     newsize.setSize(20)
>> > but I haven't yet found the correct way to update the layer's value.
>> > it seems like it needs to be passed an entire new `QgsPalLayerSettings`
>> object but I haven't found a way to build a complete object.
>> > I've seen `readFromLayer()` but I'm guessing that was a version 2
>> method that's no longer available in version 3.
>> > any pointers or a simple piece of code for updating a layer labelling
>> property would be hugely appreciated.
>> > it also occurs to me to ask whether there is anything like:
>> >     print(layer.renderer().symbol().symbolLayers()[0].properties())
>> > that returns a dict of the layer symbology properties for a label.
>> > Another helpful thing would be code that imports a label definition
>> from an exported xml file.
>> > thanks,
>> > hugh
>> > _______________________________________________
>> > QGIS-Developer mailing list
>> > QGIS-Developer at lists.osgeo.org
>> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Francisco Puga
>> iCarto | Innovación, Cooperación, Cartografía y Territorio S.L.
>> https://icarto.es
>> c/ Rafael Alberti nº 13 – 1º D
>> 15008 A Coruña
>> Galicia (Spain)
>> +34 881927808
>> Este correo electrónico contiene información estrictamente
>> confidencial y es de uso exclusivo del destinatario, quedando
>> prohibida a cualquier otra persona su revelación, copia, distribución,
>> o el ejercicio de cualquier acción relativa a su contenido. Si ha
>> recibido este mensaje por error, por favor conteste a su remitente
>> mediante correo electrónico y proceda a borrarlo de su sistema.
>> Sus datos personales serán tratados de forma confidencial y no serán
>> cedidos a terceros ajenos a ICARTO. En cualquier caso, podrá ejercer
>> los derecho de oposición, acceso, rectificación y cancelación de
>> acuerdo con lo establecido en la Ley Orgánica 15/99, de 13 de
>> diciembre, de Protección de Datos de Carácter Personal dirigiéndose a
>> Innovación, Cooperación, Cartografía e Territorio, SL. (ICARTO) en la
>> dirección postal a C/ Rafael Alberti, nº 13, 1ºD, 15.008 – (A Coruña).
> Hugh Kelley
Francisco Puga
https://icarto.es
15008 A Coruña
Galicia (Spain)
+34 881927808
Este correo electrónico contiene información estrictamente confidencial y
es de uso exclusivo del destinatario, quedando prohibida a cualquier otra
persona su revelación, copia, distribución, o el ejercicio de cualquier
acción relativa a su contenido. Si ha recibido este mensaje por error, por
favor conteste a su remitente mediante correo electrónico y proceda a
cedidos a terceros ajenos a ICARTO. En cualquier caso, podrá ejercer los
derecho de oposición, acceso, rectificación y cancelación de acuerdo con lo
establecido en la Ley Orgánica 15/99, de 13 de diciembre, de Protección de
Datos de Carácter Personal dirigiéndose a Innovación, Cooperación,
Cartografía e Territorio, SL. (ICARTO) en la dirección postal a C/ Rafael
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20221110/091ee95c/attachment.htm>
More information about the QGIS-Developer mailing list
