[QGIS-Developer] Opening, closing and removing 3D Map Views from Python?
Johannes Kröger (WhereGroup) johannes.kroeger at wheregroup.com
Tue Nov 15 04:31:31 PST 2022
Hi Martin,
thanks for your quick answer :) Dang, that's a shame but totally
understandable at the current stage. Can't wait for being able to have
scripting fun with it all! Is this on a roadmap or not planned so far?
There are no interfaces for accessing existing 3D map views either so
far, correct?
Thanks,
Hannes
Am 14.11.22 um 21:55 schrieb Martin Dobias:
> Hi Johannes
> Currently those methods are not exposed. It is not straightforward to
> expose them, because classes like Qgs3DMapCanvasWidget are only part
> of the QGIS application, not one of the QGIS libraries.
> Regards
> Martin
> On Mon, Nov 14, 2022 at 2:53 PM Johannes Kröger (WhereGroup) via
> QGIS-Developer <qgis-developer at lists.osgeo.org> wrote:
>     Howdy!
>     I've been looking around to see if we can open, close and remove
>     3D map views from Python code and I ended up not sure if or how :)
>     https://github.com/qgis/QGIS/blob/master/src/app/3d/qgs3dviewsmanagerdialog.cpp
>     shows some handling of those views and the QgsMapViewsManager.
>     In that,
>     https://github.com/qgis/QGIS/blob/master/src/app/qgisapp.cpp is
>     used as it provides various methods around this, e. g.
>     open3DMapView, close3DMapView, duplicate3DMapView, ...
>     https://qgis.org/pyqgis/master/gui/QgisInterface.html#qgis.gui.QgisInterface.mainWindow
>     says that iface.mainWindow() "Returns a pointer to the main window
>     (instance of QgisApp in case of QGIS)". It returns a QMainWindow
>     though and the *3DMapView methods are nowhere to be found.
>     Is there any way to control and manage 3D map views from Python?
>     Cheers, Hannes
>     Johannes Kröger / GIS-Entwickler/-Berater
>     Where2B Konferenz 2022
>     15. Dezember 2022 in Bonn und Online
>     https://where2b-conference.com/
>     WhereGroup GmbH
>     Grevenweg 89
>     20537 Hamburg
>     Germany
>     Tel: +49 (0)228 / 90 90 38 - 36
>     Fax: +49 (0)228 / 90 90 38 - 11
>     www.wheregroup.com  <http://www.wheregroup.com>
>     Geschäftsführer:
>     Olaf Knopp, Peter Stamm
>     Amtsgericht Bonn, HRB 9885
>     _______________________________________________
>     QGIS-Developer mailing list
>     QGIS-Developer at lists.osgeo.org
>     List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>     Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
WhereGroup GmbH
Grevenweg 89
20537 Hamburg
Germany
www.wheregroup.com
Geschäftsführer:
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20221115/ba9d1043/attachment.htm>
More information about the QGIS-Developer mailing list
