[QGIS-Developer] Mesh Layers: Way to update/repaint the QgsMeshRendererScalarSettingsWidget after recreating color ramp
Vincent Cloarec
vcloarec at gmail.com
Tue Nov 29 08:25:22 PST 2022
Hi Richard,
Can you precise how do you set the color ramp to the mesh layer ? Maybe you
set only classes (color/value) ?
Vincent
Le mar. 29 nov. 2022 à 08:47, Richard Duivenvoorde via QGIS-Developer <
qgis-developer at lists.osgeo.org> a écrit :
> Hi Devs,
> I'm loading/styling QGIS via pyqgis.
> I create my own (dynamic) color ramp, which is shown in the map.
> My issue now is that the color ram in the Layer styling widget does not
> represent the actual ramp I created (see screendump).
> I can force a 'repaint' of that widget, by adding a value in the gui via
> the green PLUS sign (and throwing it away).
> Is there a way to do this 'update' of the widget via code?
> There is no way to get to the QgsMeshRendererScalarSettingsWidget (other
> then maybe walk over the ui widget tree) is it? Or some signal I can
> emit?
> Anybody an idea?
> Or is this not something that is foreseen (I mean: loading/styling mesh
> via python code)?
> Thanks for any hints,
> Regards,
> Richard Duivenvoorde_______________________________________________
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20221129/ecd63dc2/attachment.htm>
