[QGIS-Developer] Does QgsProject.instance().createEmbeddedGroup() work?
Johannes Kröger (WhereGroup) johannes.kroeger at wheregroup.com
Mon Sep 19 00:08:02 PDT 2022
Hi Alister,
https://qgis.org/pyqgis/master/core/QgsProject.html#qgis.core.QgsProject.createEmbeddedGroup
and
https://api.qgis.org/api/classQgsProject.html#ad2e059da29ebfc32096367abb78da46c
say it should return a QgsLayerTreeGroup so I guess it is broken, at
least documentation-wise.
https://api.qgis.org/api/qgsproject_8cpp_source.html#l03274 on the other
hand hints at several "return nullptr" so it returning None is by
design. The code seems fairly readable and even has useful comments so
maybe check if one of the cases might be true in your testcase.
Cheers, Hannes
Am 19.09.22 um 05:40 schrieb Alister Hood via QGIS-Developer:
> Hi, I want to programmatically embed a project, like I can in the gui
> with "Layer>embed layers and groups."
> I thought QgsProject.instance().createEmbeddedGroup() was what I
> needed, but it doesn't seem to work - see below.  Am I completely off
> track, or is it broken?
> Thanks.
> path='/home/alister/testtoembed.qgs'
> project = QgsProject.instance()
> project.read(path)
> True
> project.clear()
> newGroup = QgsLayerTreeGroup()
> type(newGroup)
> <class 'qgis._core.QgsLayerTreeGroup'>
> newGroup = QgsProject.instance().createEmbeddedGroup('test', path, [])
> type(newGroup)
> <class 'NoneType'>
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Johannes Kröger / GIS-Entwickler/-Berater
Schon gewusst?
In unserem Blog geben wir Tipps & Tricks zu Open-Source-GIS-Software
und berichten aus unserem Experten-Alltag:
https://wheregroup.com/blog/
WhereGroup GmbH
Grevenweg 89
20537 Hamburg
Germany
Tel: +49 (0)228 / 90 90 38 - 36
Fax: +49 (0)228 / 90 90 38 - 11
www.wheregroup.com
Geschäftsführer:
Olaf Knopp, Peter Stamm
Amtsgericht Bonn, HRB 9885
Type: application/pgp-keys
Desc: OpenPGP public key
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20220919/b8e65b85/attachment.key>
Desc: OpenPGP digital signature
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20220919/b8e65b85/attachment.sig>
More information about the QGIS-Developer mailing list
