[QGIS-Developer] Does QgsProject.instance().createEmbeddedGroup() work? (Solved: yes it does)
Alister Hood alister.hood at gmail.com
Mon Sep 19 18:09:34 PDT 2022
Ah, sorry.
I misunderstood what it does  - I was thinking I could specify an arbitrary
groupName which it would create and load the layers in projectFilePath
into.
groupName is actually meant to be an existing group in projectFilePath, and
it loads that.
Thanks.
> Date: Mon, 19 Sep 2022 09:08:02 +0200
> From: Johannes Kr?ger (WhereGroup)  <johannes.kroeger at wheregroup.com>
> To: qgis-developer at lists.osgeo.org
> Subject: Re: [QGIS-Developer] Does
> Message-ID: <e2363bee-8f04-e078-4991-d704de8384ca at wheregroup.com>
> Content-Type: text/plain; charset="utf-8"; Format="flowed"
> Hi Alister,
> https://qgis.org/pyqgis/master/core/QgsProject.html#qgis.core.QgsProject.createEmbeddedGroup
> and
> https://api.qgis.org/api/classQgsProject.html#ad2e059da29ebfc32096367abb78da46c
> say it should return a QgsLayerTreeGroup so I guess it is broken, at
> least documentation-wise.
> https://api.qgis.org/api/qgsproject_8cpp_source.html#l03274 on the other
> hand hints at several "return nullptr" so it returning None is by
> design. The code seems fairly readable and even has useful comments so
> maybe check if one of the cases might be true in your testcase.
> Cheers, Hannes
> Am 19.09.22 um 05:40 schrieb Alister Hood via QGIS-Developer:
> > Hi, I want to programmatically embed a project, like I can in the gui
> > with "Layer>embed layers and groups."
> > I thought QgsProject.instance().createEmbeddedGroup() was what I
> > needed, but it doesn't seem to work - see below.? Am I completely off
> > track, or is it broken?
> > Thanks.
> > path='/home/alister/testtoembed.qgs'
> > project = QgsProject.instance()
> > project.read(path)
> > True
> > project.clear()
> > newGroup = QgsLayerTreeGroup()
> > type(newGroup)
> > <class 'qgis._core.QgsLayerTreeGroup'>
> > newGroup = QgsProject.instance().createEmbeddedGroup('test', path, [])
> > type(newGroup)
> > <class 'NoneType'>
> > QGIS-Developer mailing list
> > QGIS-Developer at lists.osgeo.org
> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Johannes Kr?ger / GIS-Entwickler/-Berater
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20220920/d047f1c7/attachment.htm>
More information about the QGIS-Developer mailing list
