[QGIS-Developer] Re-add Georeferencer action to raster menu?
Werner Macho
werner.macho at gmail.com
Tue Sep 27 00:35:13 PDT 2022
Hi Nyall, Andreas,
I fully agree with Andreas here.
Having the same functions in different locations usually only confuses the
user ("is this function doing the same as the other one?").
So -1 from me as well. The Layer menu makes complete sense with the newly
added functionality.
regards
Werner
On Tue, Sep 27, 2022 at 9:02 AM Andreas Neumann via QGIS-Developer <
qgis-developer at lists.osgeo.org> wrote:
> Hi Nyall,
> Thanks for raising this. Initially I was also confused, but the new menu
> position makes more sense.
> I would be -1 on adding it also to the raster menu. If we do add it to the
> "Raster" menu, as a consequence, it would also have to be added to the
> "Vector" menu ...
> It just needs a bit of time for people to get used to the new menu
> position in the "Layers" menu, I think.
> Andreas
> On 2022-09-27 08:40, Nyall Dawson via QGIS-Developer wrote:
> Hi devs!
> I'm after some wider feedback -- in 3.26 I moved the "Georeferencer"
> action from the Raster menu to the "Layers" menu, as the georeferencer
> was expanded to support more than just raster layers and it no longer
> seemed a logical place to put this action.
> But we've seen a lot of confusion and bug reports about the missing
> action since this move.
> I'm pondering whether we should add a second shortcut to the
> georeferncer back into the Raster menu, so that this tool will be
> available through either location.
> Is this a good idea and helps avoid user confusion? Or a bad one which
> causes more UI bloat?
> Nyall
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20220927/d2ff80ae/attachment.htm>
