[QGIS-Developer] Unclear wording for QgsDistanceArea
Johannes Kröger (WhereGroup)
johannes.kroeger at wheregroup.com
Wed Sep 28 05:42:37 PDT 2022
Hi!
I am in QGIS 3.22 in an empty project set to EPSG:3035.
Considering the following Python code run via the script editor:
>>> point_a = QgsPointXY(7.824, 48)
>>> point_b = QgsPointXY(7.829, 47.98)
>>> da = QgsDistanceArea()
>>> print(da.willUseEllipsoid())
False
>>> print(da.ellipsoid())
NONE
>>> measure = da.measureLine(point_a, point_b)
>>> print(measure)
0.02061552812809131
>>> meters = da.convertLengthMeasurement(measure,
QgsUnitTypes.DistanceMeters)
>>> print(meters)
2294.910093653533
I was wondering how it was able to turn the seemingly unit-less
0.0206... into a distance in meters and checked the docs. The
documentation
https://qgis.org/pyqgis/master/core/QgsDistanceArea.html#qgis.core.QgsDistanceArea.lengthUnits
says:
> Usually, the measurements returned by QgsDistanceArea are in meters.
If no valid ellipsoid is set, then the units may not be meters. The
units can be retrieved by calling lengthUnits() and areaUnits().
As it said "usually" and I didn't do anything special on purpose, I
expected this to return a distance measurement in meters but instead I
apparently got a distance in degrees (well, some cartesian measure
between my points as a float) which I could *convert* to meters. I have
no valid ellipsoid set so as the docs say, this could have happened
("may not be meters").
Checking the .lengthUnits() as suggested confirms that my
QgsDistanceArea somehow decided to consider my coordinate values, and
thus the measurement, to be in degrees:
>>> da.lengthUnits() == QgsUnitTypes.DistanceDegrees
True
But why? I find the language very unclear and confusing there.
Do "usually" and "may" mean that this is undefined, random behaviour
unless one explicitly sets an ellipsoid?
If so, should the docs strongly suggest to always use an ellipsoid so
that there is no "may"?
Do those words express the doc writer's vision of how the class what
usually be used?
If so, should the docs suggest a specific setup of the class?
Why did it consider my point coordinates to be in degrees?
How did it convert the degrees to meters if it supposedly does not use
an ellipsoid?
8)
Cheers, Hannes
Johannes Kröger / GIS-Entwickler/-Berater
Schon gewusst?
In unserem Blog geben wir Tipps & Tricks zu Open-Source-GIS-Software
und berichten aus unserem Experten-Alltag:
https://wheregroup.com/blog/
WhereGroup GmbH
Grevenweg 89
20537 Hamburg
Germany
Tel: +49 (0)228 / 90 90 38 - 36
Fax: +49 (0)228 / 90 90 38 - 11
www.wheregroup.com
Geschäftsführer:
Olaf Knopp, Peter Stamm
Amtsgericht Bonn, HRB 9885
Type: application/pgp-keys
Desc: OpenPGP public key
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20220928/95e48606/attachment.key>
Desc: OpenPGP digital signature
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20220928/95e48606/attachment.sig>
