[QGIS-Developer] Loading layer from specific table/view after running algorithm
Raymond Nijssen
r.nijssen at terglobo.nl
Mon Aug 7 12:00:10 PDT 2023
Found the answer to my own question in old posts here. (Thank you Matteo!)
I have added this code to the processAlgorithm() function:
context.addLayerToLoadOnCompletion(
f'{gpkg_fn}|layername=my_view',
context.LayerDetails(
name='my_view',
project=context.project()
Seems to work at least.
Raymond
On 07-08-2023 20:18, Raymond Nijssen via QGIS-Developer wrote:
> Hi developers,
> I have created a processing algorithm in python that creates a new gpkg
> database with a bunch of tables and views. One of the views can be
> loaded as a polygon layer, which works fine when loaded manually.
> How can I tell QGIS to load that view as a polygon layer when the
> algorithm has finished? (I think it must be the same as telling the
> layername to load from the geopackage)
> So far, I have tried both QgsProcessingParameterFileDestination and
> QgsProcessingParameterVectorDestination as output parameters without
> much luck.
> Hope anyone can help. Kind regards,
> Raymond
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
