[QGIS-Developer] Commit 1dca9b9 breaks build on FreeBSD with clang
Nyall Dawson
nyall.dawson at gmail.com
Thu Aug 10 20:07:14 PDT 2023
On Thu, 10 Aug 2023 at 23:20, Rainer Hurling <rhurlin at gwdg.de> wrote:
> Hi Nyall,
> On FreeBSD, commit 1dca9b9 [1] breaks the build with clang 16.0.6:
Ouch! If it's causing issues then it's fine to revert, it won't harm anything.
Nyall
> In file included from
> /usr/ports/graphics/qgis-devel/work/.build/src/core/qgis_core_autogen/mocs_compilation.cpp:132:
> /usr/ports/graphics/qgis-devel/work/.build/src/core/qgis_core_autogen/FIPKY4Q6PV/moc_qgscopcpointcloudindex.cpp:10:
> /usr/ports/graphics/qgis-devel/work/.build/src/core/qgis_core_autogen/FIPKY4Q6PV/../../../../../QGIS-1dca9b9/src/core/pointcloud/qgscopcpointcloudindex.h:109:22:
> error: no type named 'copc_info_vlr' in namespace 'lazperf'
> mutable lazperf::copc_info_vlr mCopcInfoVlr;
> /usr/ports/graphics/qgis-devel/work/.build/src/core/qgis_core_autogen/FIPKY4Q6PV/moc_qgscopcpointcloudindex.cpp:86:32:
> error: cannot initialize object parameter of type 'QgsPointCloudIndex'
> with an expression of type 'QgsCopcPointCloudIndex'
> return QgsPointCloudIndex::qt_metacast(_clname);
> /usr/ports/graphics/qgis-devel/work/.build/src/core/qgis_core_autogen/FIPKY4Q6PV/moc_qgscopcpointcloudindex.cpp:91:31:
> _id = QgsPointCloudIndex::qt_metacall(_c, _id, _a);
> /usr/ports/graphics/qgis-devel/work/.build/src/core/qgis_core_autogen/mocs_compilation.cpp:144:
> /usr/ports/graphics/qgis-devel/work/.build/src/core/qgis_core_autogen/FIPKY4Q6PV/moc_qgsremotecopcpointcloudindex.cpp:86:36:
> 'QgsCopcPointCloudIndex' with an expression of type
> 'QgsRemoteCopcPointCloudIndex'
> return QgsCopcPointCloudIndex::qt_metacast(_clname);
> /usr/ports/graphics/qgis-devel/work/.build/src/core/qgis_core_autogen/FIPKY4Q6PV/moc_qgsremotecopcpointcloudindex.cpp:91:35:
> _id = QgsCopcPointCloudIndex::qt_metacall(_c, _id, _a);
> 5 errors generated.
> gmake[4]: *** [src/core/CMakeFiles/qgis_core.dir/build.make:1557:
> src/core/CMakeFiles/qgis_core.dir/qgis_core_autogen/mocs_compilation.cpp.o]
> Error 1
> gmake[4]: Leaving directory '/usr/ports/graphics/qgis-devel/work/.build'
> gmake[3]: *** [CMakeFiles/Makefile2:4696:
> src/core/CMakeFiles/qgis_core.dir/all] Error 2
> gmake[3]: Leaving directory '/usr/ports/graphics/qgis-devel/work/.build'
> gmake[2]: *** [Makefile:169: all] Error 2
> gmake[2]: Leaving directory '/usr/ports/graphics/qgis-devel/work/.build'
> *** Error code 1
> [1]
> https://github.com/qgis/QGIS/commit/1dca9b9dbc9c790d627e8112adae7333c7a450f7
> Any ideas? Many thanks for any help.
> Best regards,
> Rainer Hurling, maintainer of the FreeBSD port of QGIS
