[QGIS-Developer] Commit 1dca9b9 breaks build on FreeBSD with clang
Rainer Hurling
rhurlin at gwdg.de
Thu Aug 10 22:54:14 PDT 2023
Am 11.08.23 um 05:07 schrieb Nyall Dawson:
> On Thu, 10 Aug 2023 at 23:20, Rainer Hurling <rhurlin at gwdg.de> wrote:
>> Hi Nyall,
>> On FreeBSD, commit 1dca9b9 [1] breaks the build with clang 16.0.6:
> Ouch! If it's causing issues then it's fine to revert, it won't harm anything.
I just double checked. Without commit 1dca9b9 I am able to build latest
version (atm commit 1a44f7b) on FreeBSD.
If it would be okay with you, the commit would be best withdrawn. On the
other hand, if there are no problems with your patch for other systems,
I can also use an appropriate (revert) patch for the port in FreeBSD.
Rainer
> Nyall
>> In file included from
>> /usr/ports/graphics/qgis-devel/work/.build/src/core/qgis_core_autogen/mocs_compilation.cpp:132:
>> /usr/ports/graphics/qgis-devel/work/.build/src/core/qgis_core_autogen/FIPKY4Q6PV/moc_qgscopcpointcloudindex.cpp:10:
>> /usr/ports/graphics/qgis-devel/work/.build/src/core/qgis_core_autogen/FIPKY4Q6PV/../../../../../QGIS-1dca9b9/src/core/pointcloud/qgscopcpointcloudindex.h:109:22:
>> error: no type named 'copc_info_vlr' in namespace 'lazperf'
>> mutable lazperf::copc_info_vlr mCopcInfoVlr;
>> /usr/ports/graphics/qgis-devel/work/.build/src/core/qgis_core_autogen/FIPKY4Q6PV/moc_qgscopcpointcloudindex.cpp:86:32:
>> error: cannot initialize object parameter of type 'QgsPointCloudIndex'
>> with an expression of type 'QgsCopcPointCloudIndex'
>> return QgsPointCloudIndex::qt_metacast(_clname);
>> /usr/ports/graphics/qgis-devel/work/.build/src/core/qgis_core_autogen/FIPKY4Q6PV/moc_qgscopcpointcloudindex.cpp:91:31:
>> _id = QgsPointCloudIndex::qt_metacall(_c, _id, _a);
>> /usr/ports/graphics/qgis-devel/work/.build/src/core/qgis_core_autogen/mocs_compilation.cpp:144:
>> /usr/ports/graphics/qgis-devel/work/.build/src/core/qgis_core_autogen/FIPKY4Q6PV/moc_qgsremotecopcpointcloudindex.cpp:86:36:
>> 'QgsCopcPointCloudIndex' with an expression of type
>> 'QgsRemoteCopcPointCloudIndex'
>> return QgsCopcPointCloudIndex::qt_metacast(_clname);
>> /usr/ports/graphics/qgis-devel/work/.build/src/core/qgis_core_autogen/FIPKY4Q6PV/moc_qgsremotecopcpointcloudindex.cpp:91:35:
>> _id = QgsCopcPointCloudIndex::qt_metacall(_c, _id, _a);
>> 5 errors generated.
>> gmake[4]: *** [src/core/CMakeFiles/qgis_core.dir/build.make:1557:
>> src/core/CMakeFiles/qgis_core.dir/qgis_core_autogen/mocs_compilation.cpp.o]
>> Error 1
>> gmake[4]: Leaving directory '/usr/ports/graphics/qgis-devel/work/.build'
>> gmake[3]: *** [CMakeFiles/Makefile2:4696:
>> src/core/CMakeFiles/qgis_core.dir/all] Error 2
>> gmake[3]: Leaving directory '/usr/ports/graphics/qgis-devel/work/.build'
>> gmake[2]: *** [Makefile:169: all] Error 2
>> gmake[2]: Leaving directory '/usr/ports/graphics/qgis-devel/work/.build'
>> *** Error code 1
>> [1]
>> https://github.com/qgis/QGIS/commit/1dca9b9dbc9c790d627e8112adae7333c7a450f7
>> Any ideas? Many thanks for any help.
>> Best regards,
>> Rainer Hurling, maintainer of the FreeBSD port of QGIS
