[QGIS-Developer] Commit 1dca9b9 breaks build on FreeBSD with clang
Nyall Dawson
nyall.dawson at gmail.com
Sat Aug 12 15:47:59 PDT 2023
On Fri, 11 Aug 2023 at 15:54, Rainer Hurling <rhurlin at gwdg.de> wrote:
> Am 11.08.23 um 05:07 schrieb Nyall Dawson:
> > On Thu, 10 Aug 2023 at 23:20, Rainer Hurling <rhurlin at gwdg.de> wrote:
> >> Hi Nyall,
> >> On FreeBSD, commit 1dca9b9 [1] breaks the build with clang 16.0.6:
> > Ouch! If it's causing issues then it's fine to revert, it won't harm anything.
> I just double checked. Without commit 1dca9b9 I am able to build latest
> version (atm commit 1a44f7b) on FreeBSD.
> If it would be okay with you, the commit would be best withdrawn. On the
> other hand, if there are no problems with your patch for other systems,
> I can also use an appropriate (revert) patch for the port in FreeBSD.
Reverted in b797724607, thanks!
Nyall
> Rainer
> > Nyall
> >> In file included from
> >> /usr/ports/graphics/qgis-devel/work/.build/src/core/qgis_core_autogen/mocs_compilation.cpp:132:
> >> /usr/ports/graphics/qgis-devel/work/.build/src/core/qgis_core_autogen/FIPKY4Q6PV/moc_qgscopcpointcloudindex.cpp:10:
> >> /usr/ports/graphics/qgis-devel/work/.build/src/core/qgis_core_autogen/FIPKY4Q6PV/../../../../../QGIS-1dca9b9/src/core/pointcloud/qgscopcpointcloudindex.h:109:22:
> >> error: no type named 'copc_info_vlr' in namespace 'lazperf'
> >> mutable lazperf::copc_info_vlr mCopcInfoVlr;
> >> /usr/ports/graphics/qgis-devel/work/.build/src/core/qgis_core_autogen/FIPKY4Q6PV/moc_qgscopcpointcloudindex.cpp:86:32:
> >> error: cannot initialize object parameter of type 'QgsPointCloudIndex'
> >> with an expression of type 'QgsCopcPointCloudIndex'
> >> return QgsPointCloudIndex::qt_metacast(_clname);
> >> /usr/ports/graphics/qgis-devel/work/.build/src/core/qgis_core_autogen/FIPKY4Q6PV/moc_qgscopcpointcloudindex.cpp:91:31:
> >> _id = QgsPointCloudIndex::qt_metacall(_c, _id, _a);
> >> /usr/ports/graphics/qgis-devel/work/.build/src/core/qgis_core_autogen/mocs_compilation.cpp:144:
> >> /usr/ports/graphics/qgis-devel/work/.build/src/core/qgis_core_autogen/FIPKY4Q6PV/moc_qgsremotecopcpointcloudindex.cpp:86:36:
> >> 'QgsCopcPointCloudIndex' with an expression of type
> >> 'QgsRemoteCopcPointCloudIndex'
> >> return QgsCopcPointCloudIndex::qt_metacast(_clname);
> >> /usr/ports/graphics/qgis-devel/work/.build/src/core/qgis_core_autogen/FIPKY4Q6PV/moc_qgsremotecopcpointcloudindex.cpp:91:35:
> >> _id = QgsCopcPointCloudIndex::qt_metacall(_c, _id, _a);
> >> 5 errors generated.
> >> gmake[4]: *** [src/core/CMakeFiles/qgis_core.dir/build.make:1557:
> >> src/core/CMakeFiles/qgis_core.dir/qgis_core_autogen/mocs_compilation.cpp.o]
> >> Error 1
> >> gmake[4]: Leaving directory '/usr/ports/graphics/qgis-devel/work/.build'
> >> gmake[3]: *** [CMakeFiles/Makefile2:4696:
> >> src/core/CMakeFiles/qgis_core.dir/all] Error 2
> >> gmake[3]: Leaving directory '/usr/ports/graphics/qgis-devel/work/.build'
> >> gmake[2]: *** [Makefile:169: all] Error 2
> >> gmake[2]: Leaving directory '/usr/ports/graphics/qgis-devel/work/.build'
> >> *** Error code 1
> >> [1]
> >> https://github.com/qgis/QGIS/commit/1dca9b9dbc9c790d627e8112adae7333c7a450f7
> >> Any ideas? Many thanks for any help.
> >> Best regards,
> >> Rainer Hurling, maintainer of the FreeBSD port of QGIS
