[QGIS-Developer] Build QGIS with PDAL on Debian bookworm: missing libpdalcpp.so
Harrissou s.
delazj at gmail.com
Thu Aug 17 14:08:44 PDT 2023
SHAME ON ME and sorry for the noise. I indeed skipped the last command to build PDAL, thinking somehow that installing it was optional and for people that actually need to run pdal commands directly.
After a sudo ninja install and adjusting path to pdal library options, building QGIS with PDAL works just fine.
Thanks Werner and Richard for showing the missing step.
Kind regards,
Harrissou
Le 17 août 2023 11:50:12 GMT+02:00, Werner Macho <werner.macho at gmail.com> a écrit :
>Hi Harrissou,
>What I see missing from your PDAL approach is the "make install" at the
>end..
>This is how the built pdal gets distributed on your OS and afterwards it
>should be available to QGIS cmake process.
>regards
>Werner
>On Thu, Aug 17, 2023 at 11:47 AM Harrissou s. <delazj at gmail.com> wrote:
>> Hi Werner,
>> I'm not on the machine I did the build earlier so I'll get back to you
>> probably tonight.
>> As for the process, I just did what is in the docs, aka:
>> - clone the repo
>> - create a build folder
>> - cd build
>> - run cmake -G Ninja ..
>> - run ninja
>> And I got no errors reported.
>> Is this different from your process?
>> I was expecting to have the files in the build/lib folder within the pdal
>> repository (what I understood from the docs). I also checked /usr/lib. I
>> confess I didn't check that /usr/local/lib folder. Will do later today.
>> Thanks,
>> Harrissou
>> Le 17 août 2023 08:41:00 GMT+02:00, Werner Macho <werner.macho at gmail.com>
>> a écrit :
>>> Hi Harrissou,
>>> I have self compiled PDAL and QGIS running on debian bookworm.
>>> It worked without any problems.
>>> First I compiled and installed PDAL
>>> Everything (including libpdalcpp.so) gets installed under /usr/local/lib
>>> and afterwards I used
>>> -DWITH_PDAL=ON
>>> to include PDAL.
>>> Everything worked smoothly.
>>> What is your workflow?
>>> regards
>>> Werner
>>> On Thu, Aug 17, 2023 at 7:42 AM Harrissou s. via QGIS-Developer <
>>> qgis-developer at lists.osgeo.org> wrote:
>>>> Hello,
>>>> I'm trying to build QGIS with PDAL on Debian bookworm and I'm failing.
>>>> As far as I can tell, Bookworm dropped support of libpdal-dev [0] so I
>>>> tried to build PDAL locally following instructions in their documentation
>>>> [1].
>>>> Everything seems to work nicely. I have the bin/pdal and tests are OK
>>>> with it, but still no lib/libpdalcpp* on my machine.
>>>> Trying to build QGIS logically ends with:
>>>> ninja: error: '/lib/libpdalcpp.so', needed by
>>>> 'output/lib/libqgis_core.so.3.33.0', missing and no known rule to make it
>>>> Anyone knows how I can fix this?
>>>> Thanks in advance,
>>>> Harrissou
>>>> [0] https://packages.debian.org/bullseye/libpdal-dev (exists in
>>>> bullseye but not bookworm)
>>>> [1]
>>>> https://pdal.io/en/latest/development/compilation/unix.html#using-ninja-on-linux-or-osx
>>>> _______________________________________________
>>>> QGIS-Developer mailing list
>>>> QGIS-Developer at lists.osgeo.org
>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20230817/87efb589/attachment.htm>
