[QGIS-Developer] Build QGIS with PDAL on Debian bookworm: missing libpdalcpp.so
Harrissou s.
delazj at gmail.com
Thu Aug 17 02:47:33 PDT 2023
Hi Werner,
I'm not on the machine I did the build earlier so I'll get back to you probably tonight.
As for the process, I just did what is in the docs, aka:
- clone the repo
- create a build folder
- cd build
- run cmake -G Ninja ..
- run ninja
And I got no errors reported.
Is this different from your process?
I was expecting to have the files in the build/lib folder within the pdal repository (what I understood from the docs). I also checked /usr/lib. I confess I didn't check that /usr/local/lib folder. Will do later today.
Thanks,
Harrissou
Le 17 août 2023 08:41:00 GMT+02:00, Werner Macho <werner.macho at gmail.com> a écrit :
>Hi Harrissou,
>I have self compiled PDAL and QGIS running on debian bookworm.
>It worked without any problems.
>First I compiled and installed PDAL
>Everything (including libpdalcpp.so) gets installed under /usr/local/lib
>and afterwards I used
>-DWITH_PDAL=ON
>to include PDAL.
> Everything worked smoothly.
>What is your workflow?
>regards
>Werner
>On Thu, Aug 17, 2023 at 7:42 AM Harrissou s. via QGIS-Developer <
>qgis-developer at lists.osgeo.org> wrote:
>> Hello,
>> I'm trying to build QGIS with PDAL on Debian bookworm and I'm failing.
>> As far as I can tell, Bookworm dropped support of libpdal-dev [0] so I
>> tried to build PDAL locally following instructions in their documentation
>> [1].
>> Everything seems to work nicely. I have the bin/pdal and tests are OK with
>> it, but still no lib/libpdalcpp* on my machine.
>> Trying to build QGIS logically ends with:
>> ninja: error: '/lib/libpdalcpp.so', needed by
>> 'output/lib/libqgis_core.so.3.33.0', missing and no known rule to make it
>> Anyone knows how I can fix this?
>> Thanks in advance,
>> Harrissou
>> [0] https://packages.debian.org/bullseye/libpdal-dev (exists in bullseye
>> but not bookworm)
>> [1]
>> https://pdal.io/en/latest/development/compilation/unix.html#using-ninja-on-linux-or-osx
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20230817/f8c134e1/attachment.htm>
