[QGIS-Developer] How to update folder with R packages in QGIS
Rainer Hurling rhurlin at gwdg.de
Wed Jan 4 13:27:43 PST 2023
Hi David,
Have a nice new year :)
Are you sure to use the right path(es)? Your first one is for a Windows
system, the second one for an Unix-like system ...
On my boxes, both places are empty, there is absolutely nothing to
update within.
In my understanding, the documentation for R scripts in QGIS [1]
describes another scenario. Perhaps it could be helpful to read the
chapters 24.10.5 and especially 24.10.6?
[1]
https://docs.qgis.org/3.22/en/docs/user_manual/processing/3rdParty.html#id13
Maybe that I am totally wrong here, but I think QGIS uses an R
installation, already present on the system. This R installation should
have the needed R packages installed and updated. In QGIS, you tell the
QGIS R provider in its processing settings, where to find this installation.
HTH.
Best wishes,
Rainer
Am 29.12.22 um 10:52 schrieb david cebrian via QGIS-Developer:
> Good morning everyone.
> I cannot run various R scripts in QGIS because I need to update various
> packages. These packages are in:
> C:\Users\david\AppData\Roaming\QGIS\QGIS3\profiles\default\processing\rlibs
> I have been told that I could update the packages by updating the folder
> rlibs in which are the  default QGIS R packages by running the following
> code in R console:
> update.packages (lib.loc="/home/david/.
> local/share/QGIS/QGIS3/profiles/default/processing/rlibs")
> Does anyone know if with this code is possible to update the R packages
> located within the folder rlibs? It seems right to me, but I would like
> to be 100% sure before running the code.
> Many thanks.
> Best wishes,
> David
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
More information about the QGIS-Developer mailing list
