[QGIS-Developer] How to find pxiels per meter resolution
Gabriele Ascolese
gab74 at libero.it
Sat Jul 1 10:01:05 PDT 2023
Hy all,
i'm developing a c++ gis using qgis api. I have a project in wgs84 projection.
I need to draw a complex poligon, so i need to find how is the pixel resolution per meters, so i can find how many pixel are in 1 meters and use this value to draw at real dimension.
How can i find the pixel per meter resolution using QGIS ? I see that WGS84 projection use degrees as measure unit..but i need meter.
Thank you
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20230701/4b71d151/attachment.htm>
