[QGIS-Developer] Implementing a updateDataSourceUriItems handler [SEC=OFFICIAL]
Lewis Rockliffe
Lewis.Rockliffe at aad.gov.au
Sun Jul 9 18:37:04 PDT 2023
I'm attempting to implement a updateDataSourceUriItems auth handler for AWS S3 based authentication
Details here:
https://github.com/qgis/QGIS/issues/53637
I think I'm misunderstanding when and how this method called when used with the GDAL raster provider, is there an example of how to set it up in python with basic http authentication?
Can anyone shed some light on this??
Lewis Rockliffe
Database and Applications Developer * Australian Antarctic Data Centre
Technology & Innovation Branch * Australian Antarctic Division
Department of Climate Change, Energy, the Environment, and Water * 203 Channel Highway, Kingston Tasmania 7050
GPO Box 858 Canberra City ACT 2601
Tel: +61 3 6232 3594 * antarctica.gov.au<http://www.antarctica.gov.au/>
------ IMPORTANT - This email and any attachments have been issued by the Australian Government Department of Climate Change, Energy, the Environment and Water. The material transmitted is for the use of the intended recipient only and may contain confidential, legally privileged, copyright or personal information. You should not copy, use or disclose it without authorisation from the Department. It is your responsibility to check any attachments for viruses and defects before opening or forwarding them. If you are not an intended recipient, please contact the sender of this email at once by return email and then delete both messages. Unintended recipients must not copy, use, disclose, rely on or publish this email or attachments. The Department of Climate Change, Energy, the Environment and Water is not liable for any loss or damage resulting from unauthorised use or dissemination of, or any reliance on, this email or attachments. If you have received this e-mail as part of a valid mailing list and no longer want to receive a message such as this one, advise the sender by return e-mail accordingly. This notice should not be deleted or altered ------
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20230710/24a5824f/attachment.htm>
