[QGIS-Developer] It is possible to protect qgisserver's wms service using authentication?
Francisco Danubio Salas Rosette
franksalas1965 at gmail.com
Thu Jul 20 19:27:28 PDT 2023
Thank you very much German, I was reading that article, I'll try to see how
I migrate that solution to linux
Regards ,
Francisco
El jue, 20 de jul. de 2023 10:11 p. m., Germán Carrillo <
carrillo.german at gmail.com> escribió:
> Hi Francisco,
> I show in detail how to set up basic Apache authentication for QGIS Server
> (using a Python plugin) in this post:
> https://geotux.tuxfamily.org/2019/05/07/accediendo-a-datos-de-qgis-server-con-base-en-roles-de-usuario/
> The post is in Spanish and is based on Windows, you would need to
> find analogue configurations for Apache in the operating system you're
> using, which should be doable.
> I hope it helps.
> Regards,
> Germán
> El mar, 11 jul 2023 a las 6:46, Francisco Danubio Salas Rosette via
> QGIS-Developer (<qgis-developer at lists.osgeo.org>) escribió:
>> Thank you very much, I will take it into account for the qgisserver
>> services that I want to give,
>> Regards,
>> El lun, 10 jul 2023 a las 11:25, Etienne Trimaille (<
>> etienne.trimaille at gmail.com>) escribió:
>>> Hi,
>>> It's something you can do in front of QGIS server. QGIS server is not
>>> connected to any ACL system by default.
>>> Or you can write a QGIS server plugin to add the authentication :
>>> https://docs.qgis.org/3.28/en/docs/pyqgis_developer_cookbook/server.html#access-control-filters
>>> Or some open source webgis based on QGIS server are providing this
>>> feature out of the box : Lizmap, QWC2,... and others as well
>>> Regards,
>>> Le ven. 7 juil. 2023 à 22:22, Francisco Danubio Salas Rosette via
>>> QGIS-Developer <qgis-developer at lists.osgeo.org> a écrit :
>>>> I have QGIS Server 3.22 running on a server with OS Debian 11, I can
>>>> request the wms service from QGIS correctly, but at no time do I establish
>>>> authentication credentials. Is it possible to configure QGISSERVER so that
>>>> it is mandatory to add the authentication credentials?
>>>> thank you so much.
>>>> Francisco
>>>> _______________________________________________
>>>> QGIS-Developer mailing list
>>>> QGIS-Developer at lists.osgeo.org
>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> |\__
> (:>__)(
> Soluciones Geoinformáticas Libres
> http://geotux.tuxfamily.org/
> https://twitter.com/GeoTux2 <http://twitter.com/GeoTux2>
> <http://gis.stackexchange.com/users/4972/germ%c3%a1n-carrillo>
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20230720/168d6f2b/attachment.htm>
