[QGIS-Developer] It is possible to protect qgisserver's wms service using authentication?
Germán Carrillo carrillo.german at gmail.com
Thu Jul 20 19:11:29 PDT 2023
Hi Francisco,
I show in detail how to set up basic Apache authentication for QGIS Server
(using a Python plugin) in this post:
https://geotux.tuxfamily.org/2019/05/07/accediendo-a-datos-de-qgis-server-con-base-en-roles-de-usuario/
The post is in Spanish and is based on Windows, you would need to
find analogue configurations for Apache in the operating system you're
using, which should be doable.
I hope it helps.
Regards,
Germán
El mar, 11 jul 2023 a las 6:46, Francisco Danubio Salas Rosette via
QGIS-Developer (<qgis-developer at lists.osgeo.org>) escribió:
> Thank you very much, I will take it into account for the qgisserver
> services that I want to give,
> Regards,
> El lun, 10 jul 2023 a las 11:25, Etienne Trimaille (<
> etienne.trimaille at gmail.com>) escribió:
>> Hi,
>> It's something you can do in front of QGIS server. QGIS server is not
>> connected to any ACL system by default.
>> Or you can write a QGIS server plugin to add the authentication :
>> https://docs.qgis.org/3.28/en/docs/pyqgis_developer_cookbook/server.html#access-control-filters
>> Or some open source webgis based on QGIS server are providing this
>> feature out of the box : Lizmap, QWC2,... and others as well
>> Regards,
>> Le ven. 7 juil. 2023 à 22:22, Francisco Danubio Salas Rosette via
>> QGIS-Developer <qgis-developer at lists.osgeo.org> a écrit :
>>> I have QGIS Server 3.22 running on a server with OS Debian 11, I can
>>> request the wms service from QGIS correctly, but at no time do I establish
>>> authentication credentials. Is it possible to configure QGISSERVER so that
>>> it is mandatory to add the authentication credentials?
>>> thank you so much.
>>>  Francisco
>>> QGIS-Developer mailing list
>>> QGIS-Developer at lists.osgeo.org
>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
   |\__
(:>__)(
Soluciones Geoinformáticas Libres
http://geotux.tuxfamily.org/
https://twitter.com/GeoTux2 <http://twitter.com/GeoTux2>
<http://gis.stackexchange.com/users/4972/germ%c3%a1n-carrillo>
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20230720/6716344f/attachment.htm>
More information about the QGIS-Developer mailing list
