[QGIS-Developer] It is possible to protect qgisserver's wms service using authentication?
Francisco Danubio Salas Rosette
franksalas1965 at gmail.com
Tue Jul 11 04:46:27 PDT 2023
Thank you very much, I will take it into account for the qgisserver
services that I want to give,
Regards,
El lun, 10 jul 2023 a las 11:25, Etienne Trimaille (<
etienne.trimaille at gmail.com>) escribió:
> Hi,
> It's something you can do in front of QGIS server. QGIS server is not
> connected to any ACL system by default.
> Or you can write a QGIS server plugin to add the authentication :
> https://docs.qgis.org/3.28/en/docs/pyqgis_developer_cookbook/server.html#access-control-filters
> Or some open source webgis based on QGIS server are providing this feature
> out of the box : Lizmap, QWC2,... and others as well
> Regards,
> Le ven. 7 juil. 2023 à 22:22, Francisco Danubio Salas Rosette via
> QGIS-Developer <qgis-developer at lists.osgeo.org> a écrit :
>> I have QGIS Server 3.22 running on a server with OS Debian 11, I can
>> request the wms service from QGIS correctly, but at no time do I establish
>> authentication credentials. Is it possible to configure QGISSERVER so that
>> it is mandatory to add the authentication credentials?
>> thank you so much.
>> Francisco
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20230711/1d89c5e5/attachment.htm>
