[QGIS-Developer] It is possible to protect qgisserver's wms service using authentication?
Etienne Trimaille
etienne.trimaille at gmail.com
Mon Jul 10 08:24:59 PDT 2023
It's something you can do in front of QGIS server. QGIS server is not
connected to any ACL system by default.
Or you can write a QGIS server plugin to add the authentication :
https://docs.qgis.org/3.28/en/docs/pyqgis_developer_cookbook/server.html#access-control-filters
Or some open source webgis based on QGIS server are providing this feature
out of the box : Lizmap, QWC2,... and others as well
Regards,
Le ven. 7 juil. 2023 à 22:22, Francisco Danubio Salas Rosette via
QGIS-Developer <qgis-developer at lists.osgeo.org> a écrit :
> I have QGIS Server 3.22 running on a server with OS Debian 11, I can
> request the wms service from QGIS correctly, but at no time do I establish
> authentication credentials. Is it possible to configure QGISSERVER so that
> it is mandatory to add the authentication credentials?
> thank you so much.
> Francisco
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20230710/d04ff07f/attachment.htm>
